Also forgot to mention I have some 33 GTR rims with Toyo R888 Proxes which aren't very old!
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $30ono
2: HKS Boost guage and loom (60mm) $50ono
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $60ono
4: 2x 5 stud 25mm Bolt On Spacers $100 - New Item - Need to sell spacers ASAP
Or take Boost guage and piller for $70.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
$120
set of Superlow King springs suit R33, only used approx 2,000kms untill the previous owner upgraded to coilovers
$40
Pair of 5MM 5STUD Spacers only done around 60-70kms?
or will swap the spacers for a working 60mm boost gauge that comes with Vacc hose etc
PM ME!
photos can be seen here
>>>photos
Edited by MRRB
For sale is my gt3076r (hks 3037 equiv) with brand new .63 a/r front housing. Was rebuilt with brand new turbine and chra internals not long ago so turbo is basically brand new. It's t3 with Garret 4 bolt dump and ex gated. Proven performer for 300-350 rwkw
Price $1300. Can post at buyers expense
Pm me if keen
In adel Sa.
TYRES
ALL PRICES ARE AS PAIRS
14"
4x 185/65 - Supercat - 60% tread - $60
15"
2x 185/55 - Hancook Optimo (one is flatspotted a little) - 60% tread - $40
16"
2x 205/55 - Mismatched pair - 60% tread - $60
2x 225/50 - Sumitomo/BJ (mismatched pair) - 50-60% tread - $50
17"
2x 205/50 - Bridgestone Potenza RE040 - 60% tread - $70
2x 205/50 - Mismatched pair - 60% tread - $60
2x 215/40 - Fulda - 50-60% tread - $60
2x 215/40 - Mismatched pair - 60% tread - $60
4x 235/45 - Bridgestone Potenza RE050A - 60-70% tread - $80
2x 235/45 - Mismatched pair - 70-80% tread - $90
2x 255/40 - Michelin/Nankang (mismatched pair) - 40-50% tread - $40
18"
PARTS
UNIVERSAL
TRUST GREDDY gear knob: $50
Blitz Mechanical Boost Gauge: $80
Blitz Blow-Off Valve w/ mandrel bent 2.5" piping: $100
R33:
Wrecking Whole R33, tell me what you're after (no gearbox or ECU)
RB25 Engine, has everything minus ECU, turbo and injectors (can include some 550's for a little extra) - $1500
6x NISMO Sidefeed 555cc Injectors (RB25) - $500
Splitfire Coilpacks for RB25 S2 - $400
GTR style fibreglass front bar (rough condition, cracks etc): $50
R33 HKS SuperDragger Exhaust: $450
R33 APEXI Front Strut Brace: $100
R33 Rear Strut brace: $90
R33 FMIC kit: $250
pics:
http://img62.imageshack.us/img62/6750/img0119jq.jpg
http://img251.imageshack.us/img251/4927/img0120ks.jpg
http://img853.imageshack.us/img853/1916/img0121dg.jpg
R33 VLSD Diff with housing and half shafts: $220
R32 GTR
R32 GTR grill: $140
Brake Master Cylinder Stopper/Reinforcer (stops firewall flex) - $80
S/S HICAS Lock Bar (extremely well built): $120
R32 GTS-T
WRECKING R32 HALF CUT MINUS ENGINE PARTS AND GEARBOX (ask in here what you're after)
Mine's Tuned ECU (genuine with certificate of authenticity plaque), to suit basic mods up to around 200rwkw, standard sensors etc - $300
R32 GTR Style Bonnet with gts-t latch (GTS-t bonnet modified to look like GTR bonnet): $180
Stock R32 Parts
Suspension/Steering
R32 GTS-t M-spec Brakes, front and rear - $500
2x Front Sway Bar - $40ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms (drivers side only) - $60ea -- PICS
2x Rear Hub Uprights - $100ea -- PICS PICS
2x Rear Complete Uprights - $70ea
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
1x Rear Toe Rod (hicas) - $50ea
Misc:
6x RB20 Injectors (standard) - $100set
1x RB20 AFM - $100
2x Doors, 2door, silver - $100ea
2x Clear Front Indicators - $60ea
2x Drive-shafts - $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
located near mitcham in SA
4: 2x 5 stud 15mm Bolt On Spacers $100 FIRM - New Item - Need to sell spacers ASAP or straight swap for 20mm spacers
r34 parts
r34 5 stud rear brake setup,hubs,hand brake cables,everything there needed for conversion $300
diff with 5 bolt half shafts 4.111 $130
all arms $40 each
hicas rack $40
bare subframe $80
drive shafts $40 each or $70 the pair or take the complete subframe for $550....
front lower control arms $180
steering rack with x member $150
front hubs $30 each
washer bottle $20
one reverse light off a 2 door $30
stock caster rods $30 each or $50 the pair
clutch & brake pedal $400
clutch master cylinder $40
clutch fan with fan $60
air con compressor $150
r33 washer bottle $20
r33 rear subframe all arms there,hicas rack $150
r33 drivers door with glass silver $100 straight as! last time i checked.
r33 stock front pipe with cat $40
r32 2 door tail lights $80 the pair
r32 power steering pump $40
r32 aircon compressor $100 has been freshly serviced not long ago
r32 aircon condenseor $80
r32 gtr front bar with lip and mesh minor damage easy fix sms for pics $300
r32gtr resistor pack $40
r32gtr window switch $30
located in athol pk 0422030855
Edited by hcR324door
hey all,
selling my yokomo RC drift car, i just dont use it anymore..
had it for about 1.5 years but for 1 year of that it has been just sitting..
comes with:
yokomo top secret s15 package.
you get everything that comes with the pack when you buy it new (even box)
extras:
1 set of wheels with grip tyres
1 set of DISH wantanabe with drit tyres (new never used)
1 extra controller with reciever
1 bigger motor and control box with reciever
upgraded shocks (fitted to the car) stock comes with car
spare chassis with bits and pieces (almost complete, but in pieces)
tools
spare s15 chassis
spare ae86
spare r34 gtr (never used, no hose cut yet for posts)
3 batteries (big 3800, 1800, 1700?)
2x chargers
here are pics:
after $500 FIRM, this is easily a 1-1.2k package.
pm me or 0433 290 801
cheers
1. JVC KD-AV7100 in excellent working order (see video below)
Price drop $250 ($999 new)
Some main features:
50W x 4
7-Inch touch screen Monitor
Front USB Port (MP3/WMA)
SD Slot (JPEG/MPEG1,2/MP3/WMA)
DVD player (dvd/cd/jpeg/divx/mp3
ipod video/audio playback
pics & details http://www.skylinesaustralia.com/forums/topic/365423-jvc-kd-av7100-powermat/page__p__5830119#entry5830119
2. As new GReddy Full Auto timer, in perfect working order
$80
pic & details http://www.skylinesaustralia.com/forums/topic/365414-greddy-turbo-timer/page__p__5830052#entry5830052
Items:
PENTAX K100D Digital SLR Camera
Item Condition:
Perfect Working order & condition
Extra Info:
Icludes Camera body + standard lens + lens caps + strap + Sigma 70-300mm Zoom Lens + manuals + software + carry bag + battery + charger
Contact Details:
please email [email protected]
Price and price conditions:
$600 for the lot ono
Parts from a S2 RB25det 133xxxkm unless otherwise stated.
PM Enquiries.
new headgasket $80
clutch fan $35
injectors and rail $50
s1 ecu $50
injector loom $40
throttle body with tps $40
r32 radiator $20 (average condition, never used)
25det block (water/oil pumps/sensors still attached) - 2 pistons damaged $150
Adjustable FPR $50 (I was told it was a nismo item but there is no brand/model/serial as far as i can see to identify)
Speco mechanical boost gauge $20
CAS - $50
Crossover intake pipe with stock BOV - $35
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
