hi all i am de modding my stagea
ive got a hks 'gt25/35 54t' turbo
fantastic upgrade for any rb 20 and 25!
huge response and great powerful turbo!
i ran this turbo on 16psi and got 260 rwkw on the neo 25, with usual mods, hit full boost at like 3250rmp :)
it is 15,000ks old, uses stock manfold, dump pipe, and cooler pipes.... great replacement for the stockie.
comes with all bolts, braided lines and oil drain, 12psi actuator (adjustable) this is completely ready to rock
$1500 plus postage
pick up in adelaide welcome or txt 0400099986
rb20/25 intercooler kit
AVARD brand, amazing quality no cutting req as it bolts from the side tanks to the chassis rails!.... no drilling cutting or ghettoness!
comes with all pipes clamps and brackets! $500 no bent fins too !!!
rb25 neo Seimens Deka injectors (top feed)
6 injecors
1x wiring loom (stock one, modded with new plugs)
2xrail spacers
all o rings etc
this will directly bolt up to your stock set up. nothing eles to worry about
$500
tein type CS coilovers
suit auto rs4 stagea (series 1 and 2)
32 wat dampner adj, heigh adj
comes with c spaners, some stickers from new, and the little dampner key.
also will include 10k old isc toe and camber arms
$850
PRICE DROP $800
Edited by chef_stagea
RETURNING TO STOCK!
All aftermarket parts for sale, Im not parting out the car only returning it to stock so if you see any aftermarket parts not listed just mention and I will grab a price.
Contact: 0401 404 104
ENGINE/POWER
- T3/T4 hi-flow turbo with VG30 exhaust housing, Comes with receipts for high flow. Currently making 252rwkw on 16 psi, If quick can be driven on the car.
$800
- Apexi Power FC, With hand controller. Comes with tune for Injectors/AFM/Turbo. $1300
- Turbo Back 3.5" Exhaust, straight through with twin 3" Stainless Steel pipes and built in Apexi Exhaust Valve Control. $650
- Z32 Air Flow Meter (Capable of 400rwkw) $200 (currently on hold)
- 550cc Aftermarket Injectors (Currently running at 77% injector cycle) $400 (currently on hold)
- Nismo Fuel Pressure Regulator $100
- Stainless Steel Intake Pipe $120
SUSPENSION
- TOP STOP Strut brace $150
- Rear Strut Brace $50
- Bilstein shocks with Whiteline Springs (Height Adjustable) $600
- Cusco Brake Stopper $60
INTERIOR
- Oil Temp, Blitz Gauge
- Oil Pressure, Blitz Gauge
- Boost pressure, Blitz Gauge $350 for all 3 gauges and senders
EXTERIOR
- DNA Wheels. 17x9 +30 all round $1100
SPARE PARTS
- JUN front bumper $150
- JUN Sideskirts $100
all up for sale I have:
1x pair stock R32 RB26 GTR manifolds $100 the pair
1x pair stock R32 Rb26 GTR turbo dump pipes $100 the pair.
1x 5-point clip-buckle harness, brand RCI. $50
1x r32 rb26 GTR oil pump, used but in good condition $50
1x r32 RB26 GTR harmonic balancer, in good condition (used) $80
1x oil catch can with mini pod-filter, brand new, $50
1x 3-guage holder set, new. $30
2x Q45 Air Flow Metres, Working condition, with plugs. $100 the pair, or $50 each
1x Z32 Air Flow Metre, working condition with plugs, $100
1x pair pod filters. Brand new never used. $50 the pair, or $30 each seperately
1x stock R32 RB26 GTR Intake pipwork, $50 the lot
1x stock R32 RB26 GTR coilpack cover blue, $100
1 x stock R32 RB26 GTR turbo two-into-one exhaust front pipe, good condition $50
1x 3" decat pipe with flex section, brand new never used $60
1x 3" twin barrel mid-muffler resonator section, brand new never used $80
1x full set Tein suspension to suit R32 GTS-T. Came out of four-door R32. Tein shocks/springs. In good condition $400
thanks. PM me and we'll arrange what you want, etc.
Offers considered
Also forgot to mention I have some 33 GTR rims with Toyo R888 Proxes which aren't very old!
taking reasonable offers now on everything but 25mm spacers, firm @ $100.
G-Tech
Injectors
Wheel studs
R32 disk brakes
etc.........
Well I've been offered $7900 as a trade in on my Stagea rs-4 1998 days edition. Refer to ad in general cars for sale.
If you can beat that offer, the car is yours. I'd really prefer it went to someone who wants one. 0421515816
Bride Low Max GIAS style (same as in pic) used in my 180 for a week and test fitted in my s15 so they are as new they are fiber glass witg black backs..... with power rails. $900 pair
bride material $100....about 1.2meters x 1.8meters
fake defi gauges new in box's never used, comes with all sensors, holders $250 for all 4
they look exactly the same as real defis
r34 rear 5 stud hubs, disks, calipers,pads, hand brake cables $300.
r34 gtt wheels with centre caps, 80% tread on 3 tires, the other has a puncture $400.
s13 sr20 5 bolt diff $40..
s15 weather shields $180 the pair
r34 4dr weather shields $100 for all 4
r34 gtt diff $100
r34 gtt power steering rack $100
located in mansfield pk s.a....pics will be up soon ....http://nissansilvia.com/forums/index.php?showtopic=493273
z32 afm sold
other stuff for sale
    • Threads merged. Only need one for the same question.
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
