still have 4 18''x8 lenso wide track rims for sale 2 in perfect condition 2 need to be re rolled due too buying them already like that,
offset= 40
comes with 4 225/40 tires in near new condition if i remember correctly.
just sittin in the garage $200
R33 gtst Parts for Sa
- Stock dump pipe $15
- Stock dump & front pipe $20
- Oxygen sensor $35
- Air Con fan $30
- Stock Intercooler + Pipes $60
- Alternator $50
- 2nd hand water pump works fine $30
- Timing belt $25
- Bosch Air con, power steering, alternator belts brand new $70
- r32 rb20det & R33 rb25det exhaust manifold gasket kit new $65
Cheers
Neo AFM - $50 - SOLD pending payment
C34 stagea lhs front fender - $100
6 coilpacks, condition unknown - $50 - SOLD
Neo engine cover - $50
RB25DET valley/coilpack cover - $25 - SOLD
Discovered I have:
another RB25DET valley/coilpack cover - $25
R33 airbox - $25
Stagea series 2 grille - $25
R33 series 1 indicators - $25
New/unused non-bosch Z32 AFM - $100
RB25DET bov - $25
PM me
Got these to clear
R33 s1 AFM - $50
q45 AFM - $100
R33 s2 plastic skirts, need a bit of repair on side mounts (crack) and tlc - $40
r33 a/c condenser core - $50
r33 std. sway bars front and rear - 6 pack Super Drys or $10 ea
Edited by SkyHi_33
R33 GTS-T
Has:
Full Body/suspension
16in wheels
3in exhaust (if not sold beforehand)
No interior but has dash, speedo steering wheel etc
Drivetrain except gearbox an tailshaft
Motor but needs rebuild
Price: $1500 take it away!!! Want it sold THIS WEEKEND!!!
Also
R33 s1 AFM $50
R33 s2 AFM $50
R33 catback 3in $100
R33 stock turbo blown exhaust wheel $50
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500
Greddy cam gears to suit RB26(new) $400
Sard FPR $80 - SOLD
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
A252X A269IN lift in ex 9:15
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$
For sale.
R33 S1 Dash 100$ - Has 3 screw holes on the passenger side as seen in picture.
10 000k HID Kit - Used for a few months but working fine - 50$ (Blue light) SOLD
Cusco Strut Brace - Type OS (New but with some scratches) - 100$
R33 and 5x114.3 super happy bargain Sale
17x9 +17 Work equips w/ centrecaps. little bit of rash and paint flaking off, but for the price you cant complain., stop fitting fake wheels and running gay widths and offsets, buy some proper Jap 2 piece wheels for the same money. 2 have no tyres, 2 have Maxxis 235/45r17 about 4mm above markers.
$1100
4x Falken ZE912 tyres. 235/45 r17 $120 each, 95% new, done under 1000kms, can do for $400 if you buy all four
R33 3" Jap cat back exhaust with a cannon $100
3" Magic Cat high flow cat, suit r33 or change the flanges to suit anything $50
r33 / 34 GTR 324mm rotors suit brembo. were just freshly machined. just RDA standard rotors. are $246ea new, 30mm new, currently have 28.9mm, min is 28mm. so just over half worn. $150 for the pair
Cusco front and rear strut braces $100 each
thanks
0411742212
JVC KW-AVX710 In-Car double DIN touchscreen DVD player
as new condition - everything works 100% - includes box and everything that comes standard
$400
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=133&modelId=MODL028304
EOI: 17" Drift R rims pending fitment of new wheels, 2x maxxis mav-1's currently on rear, pretty much brand new, been on for a few weeks and a pair of camber worn blue streaks currently on fronts. In good condition, few usual gutter marks. $700
Hey
Got a couple audio parts for sale. All parts work extremely well and have no scratches or knocks, they all look like new.
Pioneer GM-6200F 4ch x 60rms or 2 x 150rms $150.
Pioneer GM-D8400M mono block 1x300rms @ 4ohm or 1x600rms @ 2ohm. Has remote sub level controller $250.
Cheers
Edited by slippylotion
R33 GTS-T
Has:
16in wheels
No interior
Price: $1500 take it away!!! Want it sold THIS WEEK!!!
Also
R33 s1 AFM $50
R33 s2 AFM $50
R33 rear lights 100
R33 S2 rear garnish 50
r33 radiator $100
HKS SPF Pod $100
Clutch fan $40
Thermo fan $40
r33 turbo $100
R33 Airbag s1 GTR wheel $250
r33 gtr speedo 61k $400
Exedy heavy duty clutch needs new friction plate $100
S1 R33 coils $60
Many other lil bits an pieces too PM me what you want.
Few RB25 parts left over from a recent engine swap, they're all from a S2 engine.
CAS - $50
new headgasket $80
new exhaust manifold to head gasket $40
injectors and rail $70
injector loom $40
throttle body with tps $40
25det block (water/oil/sensors still attached) - 2 pistons damaged $150
Adjustable FPR $60 (I was told it was a nismo item but there is no brand/model/serial as far as i can see to identify)
PM Enquiries..
pair of Federal 595 RSRs 235/45r17, used as steer tyres for one mallala day. heaps of tread, stored inside. only selling a pair due to having several and could use the coin
$250obo
can mms pics if you need
0411742212
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
