SR20DET red top complete motor ,coilpacks, injectors, all manifolds, altenator everything except turbo . had slight bottom end noise when taken out maybe only needs new shell bearings, engine only had 120xxx kms on it anyway $600 the lot.
cheers
sparco quick release hub - $50
r32 4door rear bar - $50
r32 4door rear tail lights - $100
r32 4door boot $50
r32 passenger headlight, nothing broken - $50
r32 4door cat back, comes with gutted cat 3inch to muffler then looks to step upto 3.5inch to cannon, selling as a 3inch as im not sure - $200
r32 rear shocks with king springs? $50
r32 ganador mirrors (replica) - $150
r32 dash cluster - $50
r32 climate control - $20
r32 centre air vent - $50
r32 front wiper motor - $20
r32 4door boot $50
can i grab that indicator of ya ? check your PM'S
Hi guys, I know my post count ain't high (sorry it this appears as rude) but I have been on here for a while and placed my 2c in the forum here and there, so here we go:
PARTS MAINLY SUITED FOR NISSAN S15, but some parts are universal or will fit Skylines too.
To make it easier I have added a tag at the beginning of each line reading ALL, S15 or SR CA RB.
Located in Southern Suburbs of SA.
Pickup only at this stage.
No low-ballers please but willing to consider reasonable offers besides firm prices that are set.
Reason for sale is because I have since upgraded and no longer require the following parts:
S14 / S15: 2nd hand Hybrid FMIC - RS Spec - $200 FIRM
Great for decent power gains required on a budget without much pressure drop.
Piping is damaged but will throw that in for free as I believe there may be missing pipes too (can only find 2 pieces since my last tune and tuners changed intercooler to a Blitz CS). Buyer must arrange piping for intercooler core.
Core was previously damaged due to the preivous owner incorrectly installing it, however it has been addressed with a weld and Epoxy.
Doesn't leak any boost whatsoever from the core and if you are concerned it does then Epoxy Multi-Metal will fix it fast from your local autostore for $10.
S15: Unused Whiteline Subframe Bush set (Plus Polyurethane Type) - $150 ONO
Stiffen up that chassis and minimise that horrible noise, harshness and vibration on your daily / track car!
S14 / S15: Unused and Unpackaged K&N Panel Filter - $80 FIRM
Throw away that Ryco filter and get some air flow form a proven filter to provide better throttle resonse and economy.
JDM S15 Shifter Knob, Good Condition - $30 ONO
ALL: Unused Nismo 1.3 Bar Radiator Cap - $50 FIRM
Hold that pressure in for more effective cooling with less chance of boiling your coolant.
S14 / S15: Clutch fork pivot ball from an Xtreme Clutch set - $30 ONO
You will want this if you have an aftermarket kit and didn't install the upgraded clutch fort pivot ball to minimise the load that's placed on the standard one.
S15: 2nd Hand Gearbox and Engine Mounts from an S15, OK Condition - Make an offer $.
CA / RB: 8x NGK BCPR7ES to Suit Modified CA / RB Setups (will fit SR but not the preferred sparkplug) - $30 ONO
In regards to contacting, please PM me and we can go from there.
Cheers,
Ben.
Hey
Got a couple audio parts for sale. All parts work extremely well and have no scratches or knocks, they all look like new.
Pioneer GM-6200F 4ch x 60rms or 2 x 150rms $150.
Pioneer GM-D8400M mono block 1x300rms @ 4ohm or 1x600rms @ 2ohm. Has remote sub level controller $250.
Cheers
Open to offers guys.
For Sale:
2004 VZ SS Utility, Holden by Design, black duco, red leather interior, hard lid, tub liner, heavy duty towbar, factory Bluetooth handsfree kit, 18 inch wheels with excellent rubber, 92,000kms, regularly serviced and well maintained. $21000 ono.
http://www.carsales.com.au/all-cars/private/details.aspx?__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&R=10991881&__N=1216
Contact Anthony on 0413 807 978
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500
Greddy cam gears to suit RB26(new) $400 - SOLD
Sard FPR $80 - SOLD
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
A252X A269IN lift in ex 9:15 - SOLD
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$
hi there just cleaning out the shed and found my old wing for my s14, no need for it nomore got no car so its up for sale.condition is good. price is 250 ono
and i've got a subaru wrx 2000 model stock air intake where it goes near the wheel arch for 20 bux
please contact 0422164665
Attached thumbnail(s)
  • post-86943-0-48387900-1313021006_thumb.jpgpost-86943-0-91257800-1313021034_thumb.jpgpost-86943-0-25825900-1313021083_thumb.jpg
used suede 2 seater lounge in good nick 200 ono
a pair of potenza tyres 225/45r18 70% on both $130
R33 GTS-T
Has:
Full Body/suspension
17in wheels
3in exhaust (if not sold beforehand)
No interior however can include seats dash, speedo steering wheel etc for EXTRA price
Drivetrain except gearbox an tailshaft
Motor but needs rebuild
Price: $700 take it away!!! Want it sold THIS WEEKEND!!!
Also
R33 s1 AFM $50
R33 s2 AFM $50
R33 catback 3in $100
R33 stock turbo blown exhaust wheel $50
Price Drops left right an centre!!!!!
R33 doors mint white with windows an mirrors $300
R33 Ignition Barrel with Key $150
R33 rear lights $100
R33 S2 rear garnish $50
r33 radiator $80
HKS SPF Pod $60
Clutch fan $40
Thermo fan $40
R33 Airbag s1 GTR wheel mint condition $250
r33 gtr speedo 61k mint cond $400
Exedy heavy duty clutch needs new friction plate $50
S1 R33 coils $60
S1 R33 Front an rear seats great cond 1 small tear $150
R33 Glovebox $30
R33 dash surround $60
R33 Ashtray x2 $20 each
R33 Standard gearknob $20
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
