awesome value right there I can vouch for that product
I ran about 13.7 psi daily for about 3 years reliably
Matty see Martin when your ready to set it up I'm sure he would only charge what a power run would be worth 1 hour on the dyno at max so that may be between 70-150$
disclaimer obviously I am not the dyno operator and aforementioned price is only a guide/guess
Seems like the right idea. When they did my power fc we had some dramas with the boost control kit, so gareth put a manual bleed valve on and had it on and off the dyno in a matter of minutes! We had gone through alot of s**t and it was a dream come true to finally have the car running tip top. Above all that, no charge for dyno and i had to make gareth take a $50 note for the bleed valve! 10/10!
Back onto topic.. R32 GT-R factory front grille still for sale.. $150 (silver, perfect condition)
Also SRI hicas lock bar and bypass hose kit to suit s13/r32
Unused, still wrapped..
$100
FOR SALE: CP Pistons Sets-Nissan Skyline rb25 or rb26, 86.5 Bore
Features include:
- High strength aluminum forgings
- Super lightweight designs
- Fully CNC machined and balanced to +/- 1 gram
- Wrist pins included at no extra cost
- Accumulator groove included
- Double pin oilers, force fed from oil ring
- Pick lock grooves for easy lock removal
Comes Complete with:
(6)Pistons
(16)Locks
(6)Wrist Pins
(6)Piston Ring Sets
CP Pistons Sets-Nissan Skyline, part# sc7308
im asking $850 ONO, no reasonable offers refused
any questions please PM me, sms or call me on 0439262702
ARP NISSAN RB20 RB25 HEAD STUD KIT
THIS KIT COMES WITH: STUDS, WASHERS, NUTS, AND ASSEMBLY LUBE.
TO SUIT:
NISSAN RB20DE, RB20DET, RB25DE, RB25DET
Replace your stock head bolts with ARP heavy duty head studs. The stud design helps the head and the block equalize the pressure better thereby creating a much more even and consistent seal. It is recommended to replace the head studs/bolts with a new set if the head bolts are ever loosened due to metal fatique. Reusing an old and possibly warped or stretched head bolts/studs will sacrifice the seal between the head and block and may cause head gasket leak. This is a great an easy upgrade when doing an engine rebuild or building a race motor.
the studs are still in the box and have never been used,
im asking $200 ONO, no reasonable offer refused!
any questions feel free to PM me, txt or call me on 0439262702
RB20 - RB25 - RB30 main and rod bearing kit, .25 ovesize
ACL RACE SERIES PEFORMANCE BEARINGS
THIS KIT PRICE IS FOR A FULL SET OF MAIN BEARINGS AND CONROD BEARINGS THEY ARE STILL BRAND NEW AND STILL WRAPED IN THE FACTORY PLASTIC
BEARINGS ARE .25 OVERSIZE
$200 ONO, NO REASONABLE OFFERS REFUSED!
ANY QUESTIONS PM me, TXT OR CALL ME ON 0439262702
FOR SALE:
- HIS IceQ X Radeon HD 6950 - pretty much BRAND NEW as I've only taken it out of the box, fitted it up, havent powered up as I was short a PCI-e power cord(was going to get another one today but something has came up and rather the money) - I paid $291 posted a few days ago so it's under warranty and have receipt to prove - selling for $250 firm
Prefer SA buyers for the following to save postage so will post it up here and will open it up to interstate buyers in a few days
- rear upper adjustable camber arms to suit R32 GTR/GTST and maybe other Nissan models - $100
- pair of NISMO N1 turbos to suit RB26DETT, made 270rwkw @ 13-14psi - still on the motor, will have it out within the next day or two - $900
Expression of interest for now - let me know if you're keen, may or may not sell but currently very likely:
- RB26DETT cam covers, spark plug cover and timing belt cover - $350
- RB26DETT head - $800
Any questions feel free to PM me!
Selling a Greddy Emanage Blue.
- Universal Fuel / VTEC Harness.
- Laptop Cable
- Injector harness
- Ignition Harness
- Various connectors, cable-ties etc
- Warranty Card
http://www.ebay.com....=item2567593ce1
If a SAU member wants to pick it up before it sells will do for $300
for sale SR20DET complete engine minus turbo .Has all manifolds stater coil packs alt exhaust everything had slight bottom end noise when pulled out only 120xxxx on clock would say conrod shell bearing. want it gone need shed space and engine stand back for the RB 25.:thumbsup: $450
R33 gtst complete diff and craddle minus brakes and hubs $150 ono front cross member minus hubs and brakes $50 also a set of bilstiens for r33 say $100 ono
cheers
bilstiens and front cross member sold
cheers
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
