awesome value right there I can vouch for that product
I ran about 13.7 psi daily for about 3 years reliably
Matty see Martin when your ready to set it up I'm sure he would only charge what a power run would be worth 1 hour on the dyno at max so that may be between 70-150$
disclaimer obviously I am not the dyno operator and aforementioned price is only a guide/guess
Seems like the right idea. When they did my power fc we had some dramas with the boost control kit, so gareth put a manual bleed valve on and had it on and off the dyno in a matter of minutes! We had gone through alot of s**t and it was a dream come true to finally have the car running tip top. Above all that, no charge for dyno and i had to make gareth take a $50 note for the bleed valve! 10/10!
Back onto topic.. R32 GT-R factory front grille still for sale.. $150 (silver, perfect condition)
Also SRI hicas lock bar and bypass hose kit to suit s13/r32
Unused, still wrapped..
$100
FOR SALE: CP Pistons Sets-Nissan Skyline rb25 or rb26, 86.5 Bore
Features include:
- High strength aluminum forgings
- Super lightweight designs
- Fully CNC machined and balanced to +/- 1 gram
- Wrist pins included at no extra cost
- Accumulator groove included
- Double pin oilers, force fed from oil ring
- Pick lock grooves for easy lock removal
Comes Complete with:
(6)Pistons
(16)Locks
(6)Wrist Pins
(6)Piston Ring Sets
CP Pistons Sets-Nissan Skyline, part# sc7308
im asking $850 ONO, no reasonable offers refused
any questions please PM me, sms or call me on 0439262702
ARP NISSAN RB20 RB25 HEAD STUD KIT
THIS KIT COMES WITH: STUDS, WASHERS, NUTS, AND ASSEMBLY LUBE.
TO SUIT:
NISSAN RB20DE, RB20DET, RB25DE, RB25DET
Replace your stock head bolts with ARP heavy duty head studs. The stud design helps the head and the block equalize the pressure better thereby creating a much more even and consistent seal. It is recommended to replace the head studs/bolts with a new set if the head bolts are ever loosened due to metal fatique. Reusing an old and possibly warped or stretched head bolts/studs will sacrifice the seal between the head and block and may cause head gasket leak. This is a great an easy upgrade when doing an engine rebuild or building a race motor.
the studs are still in the box and have never been used,
im asking $200 ONO, no reasonable offer refused!
any questions feel free to PM me, txt or call me on 0439262702
RB20 - RB25 - RB30 main and rod bearing kit, .25 ovesize
ACL RACE SERIES PEFORMANCE BEARINGS
THIS KIT PRICE IS FOR A FULL SET OF MAIN BEARINGS AND CONROD BEARINGS THEY ARE STILL BRAND NEW AND STILL WRAPED IN THE FACTORY PLASTIC
BEARINGS ARE .25 OVERSIZE
$200 ONO, NO REASONABLE OFFERS REFUSED!
ANY QUESTIONS PM me, TXT OR CALL ME ON 0439262702
FOR SALE:
- HIS IceQ X Radeon HD 6950 - pretty much BRAND NEW as I've only taken it out of the box, fitted it up, havent powered up as I was short a PCI-e power cord(was going to get another one today but something has came up and rather the money) - I paid $291 posted a few days ago so it's under warranty and have receipt to prove - selling for $250 firm
Prefer SA buyers for the following to save postage so will post it up here and will open it up to interstate buyers in a few days
- rear upper adjustable camber arms to suit R32 GTR/GTST and maybe other Nissan models - $100
- pair of NISMO N1 turbos to suit RB26DETT, made 270rwkw @ 13-14psi - still on the motor, will have it out within the next day or two - $900
Expression of interest for now - let me know if you're keen, may or may not sell but currently very likely:
- RB26DETT cam covers, spark plug cover and timing belt cover - $350
- RB26DETT head - $800
Any questions feel free to PM me!
Selling a Greddy Emanage Blue.
- Universal Fuel / VTEC Harness.
- Laptop Cable
- Injector harness
- Ignition Harness
- Various connectors, cable-ties etc
- Warranty Card
http://www.ebay.com....=item2567593ce1
If a SAU member wants to pick it up before it sells will do for $300
for sale SR20DET complete engine minus turbo .Has all manifolds stater coil packs alt exhaust everything had slight bottom end noise when pulled out only 120xxxx on clock would say conrod shell bearing. want it gone need shed space and engine stand back for the RB 25.:thumbsup: $450
R33 gtst complete diff and craddle minus brakes and hubs $150 ono front cross member minus hubs and brakes $50 also a set of bilstiens for r33 say $100 ono
cheers
bilstiens and front cross member sold
cheers
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
