LOCATED NEAR MITCHAM IN SA
TYRES
ALL PRICES ARE AS PAIRS
16"
2x 205/55 - Mismatched pair - 50% tread - $40
2x 205/55 - Mismatched pair - 60% tread - $50
2x 205/55 - Nexen - 60% tread - $60
17"
2x 205/50 - Mismatched Pair - 80% tread - $70
2x 215/45 - Mismatched Pair - 60% tread - $60
2x 245/45 - Michelin/Firestone (mismatched pair) - 60% tread - $60
19"
2x 255/30 - Advan Neova AD08 - 60% tread - $110
WHEELS
Info:
Set of Rays Engineering/Volk Racing - Challenge Wheels, Genuine, no copy shit here, white with red inners. (Made in Japan)
Specs:
5x 114.3 Stud Pattern
17x8" +32 -- 235/45 Tyres (60% tread)
17x9" +35 -- 255/40 Tyres (70% tread)
Fit overs big calipers
Condition:
Great condition, a few scratches here and there, but good overall.
Price:
$950
Pics:
http://img541.images...59/img0547m.jpg
Info:
Pair of STERN Wheels (Made in Japan)
Specs:
5 - 114.3 Stud Pattern
Condition:
A few scratches here and there, but good overall.
Price:
$200
Pics:
(one on the left)
http://a2.sphotos.ak...7_6560505_n.jpg
PARTS
WRECKING BOTH R32 and R33's, post in here or PM me what you're after. a few specific parts:
TRUST GREDDY gear knob: $50
DE-CAT (gutted standard cat) suit nissan: $70
R33:
R33 GTR Rear Strut brace (fits all R33's): $90
RB25 S1 AFM: $100
R33 Brakes, uprights and hubs (complete) - $800
R33 front Upper control arms - $70ea
R33 Upper control arms/Traction arms - $50ea
R32
3" Straight Through Exhaust (from dump back) - $250
RB20 AFM: $100
R32 GTR grill: $140
Whiteline 22mm Solid Rear Sway Bar (+links): $150
REINFORCED Rear Subframe - Reinforced and Solid mounted/Lifted(improves strength, rigidity and roll centre) - $200
Front Sway Bar - $40ea
Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
Front Camber Arms - $40ea -- PICS
Rear Traction arms - $35ea -- PICS PICS
Rear Camber arms - $35ea -- PICS
Rear Hub Uprights - $100ea -- PICS PICS
Rear Complete Uprights - $70ea
Rear Toe Rods (non-hicas) - $40ea -- PICS
Door (drivers side), 2door (coupe), silver with few scratches - $50ea
Drive-shafts - $50ea
Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
For sale r33 gtst series 2 97'
Full trust exhaust with high flow cat and xforce dump
Tien coilovers ( right rear has slight nock but these are rebuildable)
Front mount
Everything else fairly standard
Needs a bit of love 100,000km service as belt sometimes squeals
Looking for 9k think that is a reasonable price
Need it gone ASAP contact me on 0401475561
Cheers
Hey guys, got the harnesses out of my old 31 here doing nothing and could use the money to finish getting stuff ready for G1 in a couple of weeks.
Sparco Harness - $100
Monza Harness - $70
Also still have the intercooler core fom the 31 too - $70!!
FS VS HSV Enhnaced Caprice V8 185 kw
Leather,cd, sub, amps,Lowered springs and shocks,Shimmed lsd,Rebuilt gearbox,Freshly serviced leads plugs oil filters.vy ss Wheels with new Tyres allround,New centre tailshaft bearing,Towbar
$8000 ono
will swap stag, aristo cash either way
Cheap Parts!!!!
need to clear our garage due to selling r33
3 inch sports exhaust w/ Jasma $100!! (not negotiable)
Has minor holes and needs to be welded to re-inforce particular areas. Hence the cheap price. muffler is rattling probably would need to be replaced
R33 Hand Brake and cable $40
R33 (guessing front 2) stock suspension and springs $40. great for regency passing defects
R33 orange stock indicators $5
R33 rear passenger tail light cover $5
R33 Rear seat belt buckles $5 for both
R33 non turbo manual speedo $40 with white dial faces 168000kms
R33 Auto turbo speedo $40 109000 (Dont think rev guage is working)
R33 Rear garnish series 2 white $30
R33 Washer bottle $5
R33 Rear passenger pod white $10
R33 Series 2 grille stock $40 (been slightly cut doesnt affect anything)
R33 Series 2 front driver fog/indicator assembly (No cover) $20
txt me and i will MMS you a picture. sorry my computer wont let me upload the pictures of thes items
0435995607
Abandoning the dream of building my low mount monster so these have to go
Hypertune single 102mm throttle body and plenum new $1500
six boost steam pipe low mount manifolds with ic pipe $500 used
sard 1000cc injectors used less than 10k $500
rb26 head with valves no cams will come with rocker and timing belt covers suit recond $400
monster twin entry cooler twin 60mm inlet 100mm outlet 140mm core has arc badge but cant be certain $1000
HKS GT RS turbos unknown kms but minimal shaft play one has a broken stud $1500
rb26 engine loom $100
Injector plate $100
Nismo afms used $500
hicas lock bar new $80
ARP headstuds for RB26 new but have been out of the plastic $250
Pm or 0411196595 cheers Scott
post-45347-0-79801800-1320128359_thumb.jpgpost-45347-0-51367200-1320128373_thumb.jpgpost-45347-0-65611400-1320128416_thumb.jpgpost-45347-0-41409200-1320128440_thumb.jpg
Edited by scotty32
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts complete $50
R33 gtst sr1 air con units that sit behind the dash, heater cores $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $10
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 rear window $70
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst false rear wall $20
RB25det stock dump on black vht $20
R33 gtst rear bar, will need small repair $25
r33 gtst sr1 power window motor regulator passenger side $70
R33 gtst rb25det hicas computer $50
ARP rb25 Exhaust Manifold Kit new never used $100
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Rb25det sr1 cas with bracket $50
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
Dave
Blitz EBC boost controller $300
5stud 25mm spacers $100 ( pair only ) for the noobs whom ask
Cusco S13 rear strut brace $120
Whiteline front s13 brace $100
brand new Sr turbo front rotors $120
plz Pm me ! located South of adelaide
Edited by PROXIMITY
Pivot Speed Meter-V - $60
Trust Airinx Air filter - $40
Stewart Warner Maximuim Perfomance Boost Gauge 25psi $50
NEO Engine cover - it's been painted red and carbon fibre strips attached. Not my thing, but might be yours. I'd happily trade it for an unmolested example. $40
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
