FOR SALE:
WHEELS NOW SOLD!!
NEW unused carbon fiber vented bonnet r33 gtst series 2.. bought it for $800 now selling for $600
R33%20GTS-T%20VENTED%20CARBON%20FIBRE%20BONNET%20BODY%20KIT%20AERO%20KIT%20AERO%20.JPG
Also got used genuine front left side control arm and also left hand side caster radius rod bracket selling due to lack of knowledge in some of adelaide's work shops.. both for $100 or $50 each.. (pics for this 2 parts on request)
located near Salisbury
Txt me anytime for any question 0415440332 cheers :)
Momo Race wheel & boss kit in good condition (to suit r32's, was on a gtr)
$150.00
Apexi Pod filters & brackets to suit R32 GTR in good condition
$150.00
6 x Standard RB26 444cc injectors, removed to upgrade
$180.00 SOLD
Located at Victor Harbor,
PM on here or sms / call 0415 117 115.
Rob
Big thick Cusco rear S13 strut Brace $100 firm
R33 GTR grill White mint condition $200
Sr S13 turbo front brand new rotors $100
Clear 180sx lights ( never seen another set same in S.A ) $200
r33 white fibreglass grill $100
r33 eyelids $50
Fuel setup , bosch 910, swirl an holder all new $300ono
r33 tailights, surrounds black $50
r32 4door skirts an pods brand new genuine nissan plastic $600 set
Text on 0407 627 431 Located South of Adelaide
Hypergear TR43, Unknown km, came out of my 1999 R34 GTT with no issues at all with it, no shaft play, no smoke, bolts straight on, comes with V band and dump, oil line (everything in the picture). - $700
Turbo Information
R34 GTT Stock ecu Auto - $150 - Sold
R34 GTT Stock Injectors x6 (Part number: FBJE100) - $100
RB25 Rocker Covers (Crinkle Black) - $60
Manual Boost Controller (think its an atomic boost controller) - $50
Turbo sold pending payment.
Hi guys got a defected 1993 R32 gtst manual
-120000 on the odometer
This car will make a great summer car,all it needs is stock suspension and silencer for the exhaust..
Its got Vertex body kit
-Fiberglass bonnet
-Wide rear
-Tein coilovers
-Front mount intercooler
-Very clean interior
-17x8 ENKEI wheels with good tires on
-Not boosted
Price is $3400
For more info call/txt on 0421072135
in case i don't answer,ill get back to you as soon as i can.
Edited by SAKS
Greddy Profec b spec 2
second hand but works perfectly. Comes with everything you need. holds stable boost without an issue. only selling due to upgrading ECU which has boost control function.
pic so you know which type
Price $300 posted.
Neo R34 Nistune ECU
Ecu is plug and play in any manual R34 or stagea with neo motor. has nistune board on it ready to go. Also has tune for e85, cams, 3076, injectors, z32 but thats useless to most people. your buying the ecu here pretty much.
Price: $600 posted
R32 GTR Radiator + Shroud
near new R32 GTR radiator from Koyo (only 3 months old) inside of core is as new condition, outside is a little muddy and dirty but will clean up no worries. With shroud which is not cracked.
Price: $300
RB clutch fan and Hub
RB30e hub (shortest of all RB hubs) and R34 neo fan, useful for running clutch fan in your RB powered S chassis
Price: $120 posted
Intercooler
300x450x76mm with 2.5inch in and outlets. ideal for mounting in tight spots. 6 months old and inside of core is spotless and oil free. minimal bent fins
Price $100
Z32 AFM with plug and Neo plenum pipe
pipe is made to relocate the AFM on the cold side of the intercooler before the throttlebody. pipe also eliminates the over the radiator location. can be adapted to fit any neo enginebay. and probably any RB engine. AFM is 12 months old comes with plug and works perfectly.
Price: $400 posted
Located Adelaide SA. can post any item
contact details.
PM me or txt 0412 938 933
-Fiberglass bonnet
-Wide rear
-Tein coilovers
-Not boosted
Price is $3400
SOLD SOLD SOLD
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts complete $50
R33 gtst sr1 air con units that sit behind the dash, heater cores $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $10
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 rear window $40
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst false rear wall $20
RB25det stock dump on black vht $20
R33 gtst rear bar, will need small repair $25
r33 gtst sr1 power window motor regulator passenger side $70
R33 gtst rb25det hicas computer $50
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Rb25det sr1 cas with bracket $50
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
Dave
R34 GTT interior/exterior parts for sale
rear boot light:$30
door trims: missing some things but either than that its in good condition: $80
parcel shelf: $40
Rear reverse lights: $30
standard oil cooler: $40
standard intake pipe: $60
rear quarter interior trims
$100
$40
R32 gts-4 complete minus engine bay and trans has gtr interior trims and recaro style front seats has sa plates $2800
I got complete R33 GTS4 series 2 running gear that sum1 could use in this car. (5 speed rb25de - ALL parts needed are there).
Hey all
Maybe moving interstate shortly so i thought id pop the hilux up for sale
Ford blueprint blue respray,less than 12months old
Rays progressiv2 rims meshies
Fronts 17x8+6
rears 17x9+13
awesome wheels and might keep them if i dont get a decent offer
Professionally lowered with pedders shocks and springs all round
C34 laurel leather and electric front seats.pimp
Tubs been shaved
4wd front gaurds and chrome grille,apron etc
Motors been rebuilt by previous owner,done about 20thousand k's since
Recently did oils,filter and brand new belts
Chassis' done over 300thousand k's but all bushes etc have been replaced
5 speed,loves to sit on 110kph on the freeway
Open to swaps for something cool,would love a 4door r32 but will look at most offers
Decent stereo with fronts in the doors,6x9s in the rear run off a sony amp,mp3 head etc
Or $8000
Slightly Less without wheels
Motorbike tie down points in the tray
Rego as a 4 seater,all belts ect in the back
Cant upload pics atm,but if anyones keen ill mms pics to them
0421754575-rodney
i have a blown RB25DET awd sump that suits a rebuild ;) R32 with awd turbo 25 would be great
Quite negotiable on the price Just need it gorne to get some cash for The D-car.So someone must want a clean car paint needs work but still clean enuf for street or can do cheaper striped So Buy my gts-4
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
