Hey Guys n Girls
Selling my HKS muffler 3.5 in 4.5 out. Has no mounts as there where used on my new exhaust. Has scuff marks on the underside but no dents.
$100
Please PM if you have any questions, Location Nth subs Adelaide
Thanks!
R33 GTS-T Series 2 Front Bar
Completely standard, no bits cut out - not even the part infront of the intercooler.
KR4 Silver
Some scratches but not too bad
dont have any photos right now but i will send pics
bought this off another member hoping to replace mine, but now im selling the car so no longer need it
located in adelaide, southern suburbs
$200
pm or sms 0413 733 433
cheers
17 x 9 Enkei 5 spoke wheels - including 6 255/40R17 tyres (4 on the wheels). 2 x tyres Maxxis @ 20% worn, 2 x Bridgestone runflats at 40% worn, 2 x Maxxis @ 80% worn (tyres not on rims)$750 ono
Work Wheel nuts x 16 brand new. Will throw in 4 x lock nuts WITHOUT key for free. Locknuts have had some extra lovin' with an extra FBH and socket....but that's another story. $100 INCLUDING post
Swirl Pot / External Fuel Pump setup. Some fittings still attached - previously housed a single 044 and was fitted to R32 GTR. Get your beast prep'd for the SAU track day and eliminate fuel surge! Fitting available. $200
Bumpelstiltskin
For anyone interested. Priorities have changed and this has to go. Show me your offers!
http://www.nissansilvia.com/forums/index.php?app=classifieds&module=core&do=view_item&item_id=1876
Time to upgrade, my Patrol is up for sale. Perfect for anyone looking for a solid tow car
Click me for more...
Nooooo not the Poontrol lol. It has surved many SAU members and shall be missed.
S2 rb25det coil packs yellow jackets less than 5000ks old $350
S2 550cc high flow injectors and rail $550
Greddy ultimate piggy back ecu books and software $500
Hey Buddy ill grab them coil packs of you today ASAP $300 ? let me kno
Contact me on 0422 102 617
turbo and air box have been sold. need to clear out the rest of this stuff so no reasonable offer refused.
open to swaps too for S15 bonnet and head lights plus cash.
cheers
R34 GTT parts for sale. All in good condition.
-turbo $350
-dump pipe $100
-injectors $350
-air flow meter $100
-intake pipe $30
-intercooler $180
-coil packs $350
-center gauges $100
-air box with new panel filter $50
-fuel pump $70
Also selling Fujitsubo cat back exhaust, not to loud, very nice note, worth big money, $800
Prices are a little negotiable.
Located in Mt Barker
PH: 0435183200
[email protected]
Prefer text messages
Cheers
PLEASE SHARE THIS AROUND!!!!
Our beloved family car was stolen today from the Mount Barker (Adelaide HIlls) Park n Ride. 97 Rs4 V Dayz Edition Nismo Red Stagea Rego XKA 074........if anyone has seen or sees it please contact police and PM me......My babys pram was in it too :((( Thanks
post-27012-0-81673100-1327040685_thumb.jpgPLEASE SHARE THIS AROUND!!!!
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
