2 X bridgestone 215/40/18 80% tread = $120
3 X bridgestone 225/40/18 30%-40% tread = $120
set of 4 X r32 gtst wheels & tyres good tread = $150
r33 gtst airbox = $50
r32 gtst front calipers, pads and rotors = $150
r32 gtst passenger seat = $20
r32 gtst rear seats & trims = $50
r32 gtst complete front hub assembly with calipers, rotors & pads = $200
rb25 turbo unknown condition = $50
garrett gt3540 turbo excellent condition, 1.06 rear housing = $550
complete rb20 engine running rich don't know what the problem is (could be injectors or tuning) turbo blows smoke, still in the car = $350
0430606223 (text&call)
Edited by r33 rb30dett
Thinking about swapping my R33 GTST series 2 turbo manual coupe. I think its a M Spec, not sure.
Has front lip, side skirts and a GTR wing. 18" dish rims.
I bought it of a bloke that looked about 60, he has owned it since 1998. (car is 1996, so he got it when it was 2 years old).
He had a few other cars so only drive it on weekend etc.
The car has now done 49,000kms (i am told genuine but can't proove). The car is mint and speaks for its self.
I am interested in swapping it for a daily driver such as:
R34 4 door turbo
Stagea
Legnum
VR4
V35 sedan
Calais.
Please sms me on 0418807844 if you are interested, I will send pics via mms. Please don't pm as my phone doesn't notify me and I won't see it.
il put $15k on it
Few car audio stuff for sale - each item is used but in good condition and works 100% - PRICES ARE FIRM:
Clarion VRX-486VD single DIN 7" DVD Player
Price: $350
Specs: http://www.clarion.com/au/en/products/2009/multimedia/multimedia_source_units/VRX486VD/au-en-product-pf_1172419833304.html
Fusion EN-AT1100 Active 10" Tube Subwoofer
Price: $100
Specs: http://www.fusionelectronics.com/car/products/active-enclosures-encounter/en-10-Active-Tube-Enclosure
Sherwood 4-Channel amplifier
Price: $50
unsure on specs - it was used to power a pair of Pioneer TSC-160R and it worked well.
1998 Toyota Starlet Life
- registered until February 2013
- 5-door Hatchback
- 5-speed manual
- power steering
- 1.3L econobox cheap on petrol
- aircondition works excellent
- dark green
- 15" ROH alloy wheels
- 2-way alarm immobiliser system
- fresh new tyres
- 206,000KM
Runs well, excellent first car and/or cheap daily, cheap on petrol and cheap to insure!
Price: $3000
Contact me on 0433743661
DVD player would be pretty baws in the truck too ;)
Already got a DVD player in the back for the little one.
Plus if I put one in the front, combined with the American spec lounge chair drivers seat, I'm likely to fall asleep driving it. Lol
- 5-door Hatchback
- 5-speed manual
- power steering
- dark green
- fresh new tyres
- 206,000KM
Price: $3000
Photos can be seen here: http://www.gumtree.com.au/m-my-ad.html?adId=1000342913
Price: $350
Price: $SOLD
Price: $50
Subwoofer sold!
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
