RB25 Standard Turbo $300
minimal shaft play, worked fine when pulled off car, held boost, no noises, clean exhaust.
RB25 Standard Turbo Manifold $75
Good condition, not warped.
RB25 Standard Front pipe $75
good condition, has O2 sensor
Kicker 400wrms mono block amp, $150
good condition
MTX Jackhammer subwoofer, 1000w peak, 250wms 12" in ported box $100
good condition, rated at 87db
Open to offers!
**cash only**
For sale: Dismantled RB20DET, currently sits as bare black on stand with everything else in box's. Engine is missing turbo, exhaust manifold, engine ECU, throttle body, knock sensors. Bores are in great condition.
Reason for sale: Bought a GTR so no longer need the engine.
Price: $300 until June long weekend. PM or txt on 0433 522 234
300$ Ono rb25 turbo mint condition no play come
Complete with actuator n snout to suit rb20.
250$ am performance screamer to suit rb, strait
Bolt on sounds sik gets bitches n shit.
200$ R32 m spec seats full set front n rear
0435163144 no pm won't get checked text only when ever
Work VS-XX Wheels - $3200
18x10 +13 - kumho KU36 tyres
18x12 -4 - Bridgestone tyres
Freshly polished and will have centers re-powder coated
RB25DET s1 motor, compression 145-160 on all 6 cylinders - $1300 ono
Comes with: Ecu, engine loom, ex manifold, alternator, ps pump, all belts and pulleys, YJ coilpacks
Does not come with: Intake manifold, injectors, injector loom
I do have a std intake manifold I can throw in for free however has no sensors.
RB25DET Manual conversion kit - $1800 or gearbox alone $1400
R33 s2 RB25DET Manual Gearbox (85,000kms)
Short Shifter
Slave Cylinder
Clutch Fork
Gearbox Crossmember
Manual Clutch and Brake Pedals
Clutch Master Cylinder
Manual Tailshaft (2dr)
Speed Sensor
Steel Braded and ADR Approved (HEL) Master to Slave clutch Line
Drivers side Gearbox loom to run manual transmission on automatic
Rubber Floor Boot
Interior Shifter surround console with leather boot
Exedy HD clutch (worn but will get you going)
RB20/25 flywheel
AM Performance split system exhaust - $1000
Decat to twin 2.5" system all the way to twin 4" pipes from diff back with titanium tips Suit GTS GTST GTR
Sparco sprint (blue) + R32/R33/A31 drivers rail 2 months old $650
Sparco Evo 2 Plus seat, no rails, brand new $650
R33 5bolt R200 diff, shimmed tight as $200
R33 s2 dash surround with vents, buttons and clock, mint $100
R33 s2 door trims with switches, mint $150
R33 s1 headlights, pair $350
Negotiable on most parts, need them gone yesterday. PM or SMS/CALL 0422 314 938
Also,
Selling the daily :)
1997 Model JZX100 Chaser Tourer V
Automatic
78,000kms
White in color
Full optional Toyota lip kit
HKS Silent cat back exhaust system (Fantastic 1jz tone without being loud!)
RSR suspension
18" Jap wheels
Lowest legal tint all round
De-badged
Just serviced and dynoed at 178rwkw
Clean inside and out, a beautiful drive!
Serious buyers please! Selling due to wanting an upgrade :)
Will consider swaps for evo 7/8, wrx sti and audi with cash adjustment upon negotiation!
PM or call/sms 0422 314 938
http://www.carsales.com.au/private/details/toyota-chaser-1997-12715342?base=1216&vertical=Car&Range=Price:Min,Max~0.5&page=1&eapi=2&sort=~Price&cr=5&__N=1246%201247%201252%201282%201216&silo=Stock&find=jzx100|CarAll
Stock parts from my R34 GTT
Doing upgrades and this stuff is no longer needed any more.
Radiator (no shroud) few bent fins,nothing major.
$80
Neo "Turtle Shell" Has been trimmed to allow for FMIC crossover pipe to fit.
$20
Neo crossover pipe.
$20
Neo ReCirc Valve (BOV).
$20
Neo Throttle body w/TCS unit (No TPS).
$40
Rb25det S2 TPS.
$30
Pink Label AFM. Excellent condition (will have plug for it when I wire up for my z32)
$60 or $80inc Plug
Stock Boost Solenoid.
$30
Stock Exhaust manifold.
$40
All Prices are ONO. Discounts for people that take multiple items.
Pick-up from Clearview 5085
Contact: Daniel 0432 838 323
Kr4 Silver R33 Series 2 bonnet. Has a small dent and a couple of small stone chips, otherwise in good condition. In Aldgate, SA but happy to freight if buyer organises and at buyers expense.
Price: $150
Contact: 0448 494 202
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash3/p480x480/554828_3875397161923_1188513835_3557659_1298648386_n.jpg
F/S Hi-Flowed RB25 Turbo. Minimal shaft play, running standard boost.
$300
How much power did you get from the turbo and how much use has it had?
Interested
Up for sale is a GCG gt3582 based turbo, would love to use it on my rb25 but it's way too large for drifting duties.
It is a GCG 3566R which is made with all garret parts to GCG specs. Its rated at 750 - 800hp so it will easily make 300kw at the wheels on any car with the right mods with the potential to make well into the high 400's Turbo does have oil and water fittings but no lines as i never got the chance to get them made. It is in great condition with no shaft play or damage
Included is;
GCG 3566R Turbo
One Piece Front/Dump Pipe and Cat
Ball Bearing
Oil & Water Cooled
Externally Wastegated
T3 flange
0.70a/r Compressor Housing
4" Compressor Inlet
2.5" Compressor Outlet
0.82 Exhaust housing
$1000 firm
Give me a buzz on 0431 836 94O
Check out GCG's site for more info
http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=335&category_id=34&option=com_virtuemart&Itemid=53
For Sale: Fibreglass R32 gtst Type B front bar from Viva Garage. No longer have the car it was going on so no need for the bar. Looks just like an R33 GTR front bar. Bar is not painted.
Price: $200 if sold before June Long Weekend after that it will be $250. At $200 i'm loosing money.
Located South of Adelaide. PM or txt on 0433 522 234
still on the car but will be off soon
injectors to suite rb20 turbo can be made to suite silvias or gtsts etc..
nismo 600cc injectors purple ones - $350
2860RS disco potato turbo done less than 1000ks - $1250
32 GTR cams - offer ?
R33 s2 i think drivers side door was white now in primer plus s2 door cards for both sides - offer ?
ESP left handed guitar and massive amp , pedals, stand, leads etc - $1200
home gym set up - $350
PM or text 0421549607 for pics and more info on anything. cheers
Hey guys have a few 2 way KAAZ diffs here, both have the same 4.36 ratio centres with S13/R32 housings, but 1 comes in a housing with 5 bolts half shafts, and the other comes in a housing with 6 bolt half shafts.
chasing $750
located near mitcham in SA, can post anywhere in Aus.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
