FS:
Bilstein coilovers suit R32
Medium stiffness spring rates (cannot confirm exact spring rates)
Great condition.
Only selling due to wanting stiffer coilovers to suit my application (drift).
$700.
NEED THEM GONE.
Hey... got some parts in the shed that I need to clear.
ca18det full engine loom= $150
S14/S15 struts with lowered King Springs= front and rear. Excellent Cond, pulled from a low km S15= $250
S14/S15 front struts with lowered King Springs. Struts are average cond but springs are good
= $50
I will get part number asap on the springs above.
From memory the fronts will also with RS-V Stagea's.
2 x New D2R 4300k HID Xenon globes= $20
2 x New D2R 6000k HID Xenon globes= $20
I will get pics up asap.
I can help with postage at buyers expense or pick up from Gepps Cross or Blakeview.
Stock parts from my R34 GTT
Doing upgrades and this stuff is no longer needed any more.
Radiator (no shroud) few bent fins,nothing major.
$80
Neo "Turtle Shell" Has been trimmed to allow for FMIC crossover pipe to fit.
$20
Neo crossover pipe.
$20
Neo ReCirc Valve (BOV).
$20
Neo Throttle body w/TCS unit (No TPS).
$40
Rb25det S2 TPS.
$30
Pink Label AFM. Excellent condition (will have plug for it when I wire up for my z32)
$60 or $80inc Plug
Stock Boost Solenoid.
$30
Stock Exhaust manifold.
$40
All Prices are ONO. Discounts for people that take multiple items.
Pick-up from Clearview 5085
Contact: Daniel 0432 838 323
Some bits sold, rest still needs to go.
Got a complete set of R35 GTR brakes for sale off our old white car (they havent been on it since mid 2011)
Thats front and rear calipers, AP Jhook disks (couple of sets, some well used, some still ok) and some Endless pads about 60-70% worn
Take the lot and have the best brakes you have ever seen on an R32,33,34 for $2500....
Pm me!
Probably Matt, I had some fitted to a Navara for a local guy.
Anything can be fitted to anything - no we wont do it - but can point you in the right direction of someone who will :)
Bring money - all yours!
haha
ill call past quickly on friday.
is pure blond still drink of choice?
house settlement end of july so then its game on;)
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
