R33 side feed nismo 550cc injectors (yellow) 5000kms old
They come complete in the rail ready to go straight in
They are still in my car and will remove them when sold
Only selling to upgrade to e85
$500
Brand new r33 GTR jun style carbon front lip
$360 firm
17inch buddy club p1 racing originals in hyper gold
Mint con, tyres just about all had it
Nissan 5 stud patten
Unsure on width and offset will update soon
If your interested just text me and I'll go check
$750
0407083177 - Joey
Edited by joeyy
Got a heap of parts to get rid of. Moving at the end of the month and want to get rid of as much of it as possible. Make a decent offer and it's urs
S13/180SX - STOCK
stock front pipe
stock dump pipe with oxy sensor
4 stud hubs with good bearings
sr turbo front brakes with disks and pads
Hicas power steering resivour with level sensor
Hicas subframe with all Hicas lines, senders, lower control arms, disks & knuckles
AC condensor with lines
AC compressor with idler and brackets
R180 diff (suit 5x1 half shafts)
half shafts (5x1)
interior fan and heater core
AC interor core
hicas PS pump
T25 turbo on standard manifold
clutch fan shroud
stock intercooler with piping & BOV
charcol canister
standard suspension arms
most interior parts available
AFTERMARKET
Blitz aluminium mandrel bent piping to suit front mount
3" front dump pipe (mandrel bent, mild steel) with oxy sensor
C34 STAGEA
wrecking a c34 stagea (no gbx, motor), if any parts u want aren't listed let me know as i probably have it
nismo front suspension (springs & shocks, not height adjustable)
standard rear suspension (springs & shocks)
interor fan with heater core
AC interior core
front seats
door shells
rear hatch shell
roof rack
dash
carpet (minus hatch area)
headliner
visors
rear seats (top section only)
steering wheel (with radio controls) no centre
auto shifter
wiper and indicator stalk assemblies
front & rear seat belts
front AWD knuckles with 5 stud hubs
ABS unit
front X-member
rad overflow bottle (good condition)
UNIVERSAL
5x114.3 space saver spares
floor mats
4x114.3 space saver spares
4x 17"x7.5ish ROH adrenalin rims without tyres (4x114.3). can get specific offset/width if required. Can be freshly sprayed (rattle can) if needed
4x 17"X7.5ish speedy rims with pretty much gone tyres, one rim damaged (probs beyond repair). 4x114.3. can get specific offset/width if required.
Also have an NA R33 manual with full kit and a MQ patrol diesel 4 speed man for sale, soon to be posted
ph. 0407971706
Whats going on fellas, been a while since I've pocked my head around these neck of the woods...
Got my drifter up for sale.
Im selling up for a clean streeter as I get my full license back November :).
ENGINE:
JZS147 2JZGTE approx 110xxxkms
Cast single turbo manifold T4 flange 38mm wastegate
GT3582 anti surge turbo .82 ATP rear housing T4 flange
Custom oil + coolant turbo braided lines
JZA80 water pump
Re-routed wiring looms + bonnet cable to engine bay
GKtech plastic overflow bottle
Walbro GSS442 high pressure fuel pump
Removed throttle body traction control
Light weight drive pulleys
Sard radiator (S14) + custom piping
Front mount intercooler 450x300x76 + custom piping
HKS oil cooler core
Oil filter relocation kit + custom lines + Speedflow fittings
Oil catch can
Modified rocker covers with Speedflow fittings
Tial 38mm external wastegate
Bee R rev limiter
HKS FCD
3" custom exhaust turbo back 1 muffler
Custom accelerator cable
Radiator shroud with 2x 12” thermos
Turbo heat blanket
POWER: 299RWKW, 840NM @ 17PSI
DRIVETRAIN:
R33 RB25 gearbox
Cut and shut RB>2JZ bellhousing
Billet flywheel (W58)
single carbotic 5-puk clutch (RB25)
1300KG pressure plate (W58)
Custom 1 piece 3" tailshaft
Welded R200 diff + 5 bolt half shafts 4.1 ratio
Powered By Max solid subframe risers
R34 rear 5 stud hubs
Super Now engine mounts (R32)
Super Now gearbox mount
Craig Helps engine block mounts
Custom gearbox xmember (R32)
S14 clutch master cylinder
Braided + custom clutch line
Uras solid shifter (R34)
Enkei wheel nuts
AMG style 17x9+11 (pair) REAR
Mesh style 17x9.5+15 (pair) FRONT
SUSPENSION:
KTS rear strut brace
JIC FLT-FAS coilovers 7k front 5k rear
S14 LCA’s modified/boxed + S13 balljoints
Kazama castor arms
Tomei 3 point front strut brace
A31 front sway bar
STEERING:
S14 steering rack
Ikeya Formula tie rods
KTS roll centre adjustment tie rod ends
KTS aluminium steering rack bushes
GT-1 Motorsports steering bush
BRAKES:
S14 front 4 piston calipers
Project Mu front rotors
Braided front lines
S14 BM44 master cylinder
Hydro h/brake installed under standard console
INTERIOR:
Pioneer front 6” speakers
Works Bell boss kit
Works Bell quick release with flipper
Works Bell steering wheel 330mm
Yashio Factory spin turn knob
Bride Zeta III (Red with gradient)
Bride seat rail
Cusco D1 8 point roll cage
Okuyama Carbing gear knob
Blitz SBC
Sard battery box
Isolator switch
Broadway mirror
Apexi water temp + oil temp + oil pressure gauges + controller
Alpine CD/MD player
Type X passenger seat
EXTERIOR:
S13 silvia front end
Blacked out quarter windows
Flared guards
Resprayed red
0433 830 055 | $10,500
$500- SOLD
$360 firm
$750
0407083177 - Joey
Sard fuel rail brand new never used with all fittings $200
Sard fuel pressure regulator brand new never used $500
Parts will brought from RHDjapan but have decided to used stock rails instead.
Pm me if you are keen
few things ive got lying around
R34 gtt decat its a just jap one - $30
R34 spoiler KR4 silver in colour, couple of small marks - $50
R32 wastegate actuator 10psi - $25
Turbotech boost tee, pretty much new - $25
Pioneer deh-1350 mpg stereo, pretty much new comes with nissan harness for plug and play - $50
Clutch fork pivot ball, New in wrapper part no 30537-40p01 think it suits r33 - $5
and a left hand side r34 weather shield - free
Ben - 0433 987 945
Up for sale is my R33 GTS25T Series 2. Selling as I now have a work car and don't need two cars.
This car is in excellent condition, very clean and unmolested. Only mods are exhaust and pod filter, rest of the car is stock.
Has travelled 106850 KM always serviced, timing belt was replaced at the 100000 KM service.
New front tyres
New battery
New Coolant
New tint
Pioneer 6 stack DVD/CD with remote and vehicle dynamics processor module
Alarm system
Registered till 19/10/13
If you are looking for a clean 33 check this one out, has been owned by a mature aged person and it has not been thrashed, raced or tracked.
Asking for $10000.00 Negotiable - reasonable offers considered.
Phone - 0438 830 788
post-79573-0-10465500-1376022008_thumb.jpgpost-79573-0-11885300-1376022063_thumb.jpgpost-79573-0-16868800-1376022120_thumb.jpgpost-79573-0-66621400-1376022205_thumb.jpg
R33 3" Catback to AMPerformance 4" Twin Tips.
Asking $400.
does anyone know if this would be louder than my hks 3" straight pipe exhaust which i have on. my current exhaust is just under 90db.
Id guarantee it
Ben - 0433 987 945
Asking $400.
Bump - $300 :( Last price drop. I want this gone and I'm pretty sure that $300 is dirt cheap as well.. :(
R33 GTR carbon front lip *brand new*
$300 if gone in the next few days
Buddy club p1 racing originals
Good condition , slight rash on 2 rims
Front tyres ok. rears finished
17x9 5 x 114.3
$700
Call or text any time
0407083177- joey
Edited by joeyy
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
