picked up a crashed s14 series 2 from the auctions to part out, complete sr20det engine/box package $2400, has complete set of stockies few marks but near new tyres 2 different pairs think federals and kuhmos $250, r33 kr4 silver s2 wing $20 r33 dash surround $30 pm me if you need bits :P
Righto, had enough low balling.
I am now stripping the below.
If you need anything Holla at me and I'll give you a price and a date/time when I'll have it off the car.
Regards,
Weez :D
Whats going on fellas, been a while since I've pocked my head around these neck of the woods...
Got my drifter up for sale.
Im selling up for a clean streeter as I get my full license back November :).
ENGINE:
JZS147 2JZGTE approx 110xxxkms
Cast single turbo manifold T4 flange 38mm wastegate
GT3582 anti surge turbo .82 ATP rear housing T4 flange
Custom oil + coolant turbo braided lines
JZA80 water pump
Re-routed wiring looms + bonnet cable to engine bay
GKtech plastic overflow bottle
Walbro GSS442 high pressure fuel pump
Removed throttle body traction control
Light weight drive pulleys
Sard radiator (S14) + custom piping
Front mount intercooler 450x300x76 + custom piping
HKS oil cooler core
Oil filter relocation kit + custom lines + Speedflow fittings
Oil catch can
Modified rocker covers with Speedflow fittings
Tial 38mm external wastegate
Bee R rev limiter
HKS FCD
3" custom exhaust turbo back 1 muffler
Custom accelerator cable
Radiator shroud with 2x 12” thermos
Turbo heat blanket
POWER: 299RWKW, 840NM @ 17PSI
DRIVETRAIN:
R33 RB25 gearbox
Cut and shut RB>2JZ bellhousing
Billet flywheel (W58)
single carbotic 5-puk clutch (RB25)
1300KG pressure plate (W58)
Custom 1 piece 3" tailshaft
Welded R200 diff + 5 bolt half shafts 4.1 ratio
Powered By Max solid subframe risers
R34 rear 5 stud hubs
Super Now engine mounts (R32)
Super Now gearbox mount
Craig Helps engine block mounts
Custom gearbox xmember (R32)
S14 clutch master cylinder
Braided + custom clutch line
Uras solid shifter (R34)
Enkei wheel nuts
AMG style 17x9+11 (pair) REAR
Mesh style 17x9.5+15 (pair) FRONT
SUSPENSION:
KTS rear strut brace
JIC FLT-FAS coilovers 7k front 5k rear
S14 LCA’s modified/boxed + S13 balljoints
Kazama castor arms
Tomei 3 point front strut brace
A31 front sway bar
STEERING:
S14 steering rack
Ikeya Formula tie rods
KTS roll centre adjustment tie rod ends
KTS aluminium steering rack bushes
GT-1 Motorsports steering bush
BRAKES:
S14 front 4 piston calipers
Project Mu front rotors
Braided front lines
S14 BM44 master cylinder
Hydro h/brake installed under standard console
INTERIOR:
Pioneer front 6” speakers
Works Bell boss kit
Works Bell quick release with flipper
Works Bell steering wheel 330mm
Yashio Factory spin turn knob
Bride Zeta III (Red with gradient)
Bride seat rail
Cusco D1 8 point roll cage
Okuyama Carbing gear knob
Blitz SBC
Sard battery box
Isolator switch
Broadway mirror
Apexi water temp + oil temp + oil pressure gauges + controller
Alpine CD/MD player
Type X passenger seat
EXTERIOR:
S13 silvia front end
Blacked out quarter windows
Flared guards
Resprayed red
0433 EIGHT THREE ZERO 055
Northern end of Adelaide, selling shit from my R32 and R34.
R34 GTR dash.
suit manual.
180kmph 10,000RPM brushed silver.
only taken out to take photo, and yet it has the clear plastic cover....its just to clear to see ;)
$250
Stock standard R34 gtt exhaust
kept it incase i got defected.
this is a full dump pipe - cat - muffler - rear muffler - tip.
great condition.
(not all pictured but all there)
$300
R34 gtt wing
Silver,
Bolts and all.
$200
R34 GTT smic
good condition with hard pipes included
$300
R34 GTT chrystal side indicators
brand new unused
$50
R34 gtt orange front repeaters
excelent condition
$20
2X 6000k xennon globes,
they are slightly different colours, you can notice the difference but its slight. i always had them for spares
to suit R34 xennons
$20 for both
R32 GTR coilpacks
excelent condition
$200
R32 xennon front section
does not come with balasts
ignore the stickers they are 8000k
$50
other random shit for sale
R34 gtt washer bottle with neck $30
Neo engine cover $50
stock R34 GTT struts, good shocks normal springs $200
ask for better picks and ill drag it out.
pm me here or sms 0413145430
glyn
more to come
R34 side plastic door scuff plates $20
R34 top half of intake plenum $10
RB clutch fan $30
R34 turbo front and rear brakes $600
R34 boot carpet $10
R34 Sub box $50
R34 Front Innder plastic guards $50 (pair)
R34 Apexi FMIC $300
R34 Alternator $50
R34 Steering pump $50
R34 Sunroof $50
R34 Passengers guard $100
R34 3.5" turbo back exhaust $500
R34 Passengers door $100
R34 Nismo coilovers $600
R34 Tein Coilovers - Super Street with incar damper adjuster $1000
R34 Jim Berry clutch $500
R34 adjustable castor rods $150
R34 Kazama adjustable castor rods $180
R34 KOYO radiator $200
R34 Centre gauges $100
R34 Centre stereo surround $70
R34 Middle dash vents $50
R34 Airbox $50
R34 AT surround $20
R34 window wind deflectors $100
R34 dash cluster $40
R34 Drivers side mirror $50
R34 carbon fibre b pillar plastics $70
R34 Brake master and booster $100
R34/ RB25 Greddy Genuine Plenum $650
RB20/25 Flywheel $100
RB 20/25 Exedy clutch 5 puk $50
RB 20/25 Extreme plate $20 (worn)
R33 lowered suspension $150
R33 3" front/dump exhaust $150
R33 Window washer bottle $30
R33 Radiator bottle $30
R33 Tomei strut brace $100
R33 power steering pump $50
R33 Driveshafts $100
R33 Standard suspension $50
R33 tomei short shifter $100
R33 S2 Coilpacks $100
R33 S2 Coilpacks loom $50
R33 AC condenser $50
R33 AFM $100
R33 drivers guard $30
R33 B44 brake master $70
R32/s13 nismo diff in housing 4.1 Ratio $700
R32 GTR Apexi Super Intake Kit $200
R32 HKS mushroom kit $200
R32 front indicators (pair) $100
R32 gtr rear brakes $150
R32 Nismo rear arms $200
R32 gtr rear seats $100
R32 Type m side skirts $50
R32 dash cluster $50
S13 Rear light Drivers Side $30
Carbon fibre drift wing $250
35mm bolt on spacers $100
15mm bolt on Spacers $100
Tomei Super Hicas lock kit with plug in computer to trip the dash and shims for Hicas Rack (Passes regency) $100
Q45 AFM $150
A31 grill $50
180sx origin roof spoiler $150
If your after more details please just PM me. Possibly interested in swaps for a cheap pair of 16" X 9" Wheels (maybe old supra wheels) or even R32 GTR wheels
Edited by JiN_MaN
For Sale:
.Used Genuine Nismo R32 gtst front camber arms $100
.Used R32 gtst rear camber arms $40
.Used Digital Drift Vaccum guage with loomb $80
.Used Apexi R32 GTR Pod Filter Kit $180
.R32 GTR front shaft from transfer case to front diff $150 firm
Pics on request.
Items located Morphett Vale or can bring to work down at Wayville.
Txt on 0433 522 234 for more info
Pm sent re plenum
RB clutch fan $30
R34 boot carpet $10
R34 Sub box $50
R34 Apexi FMIC $300
R34 Alternator $50
R34 Sunroof $50
R34 Airbox $50
R34 AT surround $20
R33 AFM $100
Q45 AFM $150
A31 grill $50
Got an R32 4 door roof wing.
Bought it and then decided I wanted to go for a different look.
offers via txt to 0416 580 two two three
SOLD
Edited by CRSKmD
few things ive got lying around
R34 gtt decat its a just jap one - $30
R34 spoiler KR4 silver in colour, couple of small marks - $50
R32 wastegate actuator 10psi - $25
Turbotech boost tee, pretty much new - $25
Pioneer deh-1350 mpg stereo, pretty much new comes with nissan harness for plug and play - $50
Clutch fork pivot ball, New in wrapper part no 30537-40p01 think it suits r33 - $5
and a left hand side r34 weather shield - free
Ben - 0433 987 945
Decided to put my quiet exhaust back on so also have a full 3" stainless steel catback, small oval muffler at rear, made by AMPerformance and done a max of 1000km, not a scratch on it - $450 (suits R34 gtt)
For Sale ; Nissan Stagea 2001 250 t rs four v
85000 kms
$14500 ono
Advertised on Gumtree and Carsales , recent exhaust work done by Mark at Exhaust technology , otherwise un modified .
Unique factory body kit and very clean inside and out .
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
