f/s-
i have a 38mm turbosmart wastegate.
fitted with a 7psi spring.
it held 15psi FLAT on my 25 with 3076r.
ONLY upgrading due to getting a craig helps merge collector manifold and HAVING to go 44mm or bigger :ermm:
used for 100km's
$300
up for sale my 32 CBF fixing it
up for sale is my r32,gts 4wd turbo AUTOMATIC.
black in colour
with 146000kms
rb20 DET
3inch cat back exhaust
17inch black r34 gtt rims
tinted windows
very clean body
bad points are little things like a few plastics in the interior are broken
NEEDS r/h side controll arm, front bar and tire to be swapped over as it has a puncture but i have a tire to go on.
and no rego but it can be all you have to do is go to the rego office and pay for it.
price is firm as its CHEAP as CHIPS , no swaps BUT i want a bigger turbo for my 33 so maybe cash a turbo and cash.
text me on 0415232397 located in mansfield pk
pics here...http://nissansilvia.com/forums/index.php?showtopic=463264
4 Sale
R32 ISC Rear camber arms, Brand spanking!
Bought coz they were going to on the track car but decided to take the ones off the streeter instead.
Bought for $179 (+15 bucks postage i think).
Sell for $150
z32 afm setup for 5-pin plug (suit Rb20, early-mid Rb25) still for sale - $100
I have some sets of Front Brake disc rotors (pairs) for sale:
1x DBA4000 296mm x 30mm 99% new. R32 GTR
unused from project, upgraded to 324mm set
had slight surface moisture rust, sandpapered off as per pic
$100
1x RDA 280mm x 30mm 90% new. R32 GTst, Stagea S1
had slight surface moisture rust from leaking shed, sandpapered off
$80
1x RDA 280 x 29mm 75% new. Stagea s1, R32 GTsT
$70
1x stagea S1 front brake caliper set, with braided line as pictured, new pads
$50
need it gone
thanks
FOR SALE:
Carbon bonnet for r34 300$
Blitz LM fmi return flow type r34/33 300$
R34 Nismo/Altia rear bumper, original not fibre glass copy 150$
pm me if your interested!
PM sent for bonnet and FMIC
cheers
for sale
genuine r34 aero front bar 500 neg
fibreglass aero front bar brand new still in gel coat, no pic 150 neg
brand new never been used greddy dual pillar gauge holder for r34 gtt/gtr 120 neg
msg or ring dylan on 0433091947
Bendix Ultimate Pads + Discs To Suit R33 Skyline
Includes:
Front Discs x2
Rear Discs x2
Front Pads x2
Rear Pads x2
Not sure on the true value of these, so if some makes a good offer i will probably take it
These are also listed on ebay at the moment, here's the link to view pics of the dics and pads
http://cgi.ebay.com.au/Complete-Set-Brakes...=item3a5f3a5ae5
The discs have hardly a lip at all on them at all, the front is like not even a 1mm lip i rekon,
And as for the rear discs, they just feel like there is no lip, just where the pad doesn't reach the edge of the disc its a lil rough, which is normal
The pads have 7mm all round front and rear, and they are Bendix Ultimate,
Do not want to post as too heavy being metal, obvious reasons ofcoarse. Would prefer pickup only
Contact me through here or send me an e-mail at [email protected]
Locater in craigmore 5114
r32 standard turbo. Came off the car running stock boost before I did a turbo/injector upgrade. $200.
Set of rb20 injectors $100
rb20 airflow meter $70
prices are neg. I am willing to swap parts for the following things--
Bonnet. Drivers side front guard. Drivers side head light and indicator to suit r32.
Pm for details thanks
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
