R32 GTR bits and pieces
1. side pipe. bolts from y pipe flange in place of cat and rest of pipework. 2.5", dumps in front of rear wheel. good quality, nice and loud
2. GTR front swaybar
3. GTR rear swaybar
4. GTR front upper arms
5. GTR rear camber arms
PRICES
1. $90 bargain - pickup only. perfect for track days :P
2. $100 - links included, bushes need replacement
3. $100 - links included, bushes need replacement
4. $50 - good nick
5. $80 - good nick
CONTACT VIA PM
Sorry guys
just sold both of them
it was a series 2 guard came off the wreck i bought..
if anyones interested in
4 stud non-turbo front & rear rotors
4 stud front hubs
5 stud front hubs
rear brakes off a non turbo 33
let me know
if you really wanted you could get them re-drilled to suit 5 stud
i need to clear this shit before relatives come down from QLD
cheers guys
what is the difference?? never notice
different shape fender^
lights are an easy give away, s2 lights are a much flatter edged/sharper shape compared to s1
The front lights are different shape, pretty sure the whole front end is different ie the bonnet is slightly different and so is the front bar. the boot lid is a tad different too
Yeah thats mostly right.. The headlights, bonnet, front bar, reo bar are the different things.. The fenders are the same.. Also the bootlid is the same just a different spoiler..
there is a slight difference in the boot lid Dom. notice where is says "SKYLINE" on a series 1 its on a plastic strip and on the series 2's its actually etched into the boot lid. I also doubt that the fenders would be the same as the shape of the lights are different??
yeah thats correct Krishy .. because i had that series 2 fender on my series 1 with series 1 lights and it matched up. I started a topic a few months back from now because i was unsure about this and a member on her named "S1LV3RTRACKS" had confirmed they were the same. I think a slight difference was a pocket of something in the drivers side. But i may be wrong.. Can anyone else confirm this?
got 2 pairs of 18" tyres with good tread i need to get rid of, was keeping them to use on my car but ended up selling the wheels.
First is a pair of 245/45/18 Zeetex with around 70% tread remaining. After $200 for the pair.
Second in a pair of 275/35/18 Nexen with around 50-60% tread remaining. After $200 for the pair.
245/45/18 your location ? contact number ? cant pm yet
Selling off last shit need gone ASAP
Greddy WJ-36 Radiator Hose Temperature Sensor Adaptor - $50
Comes with piping
R33 Stock Air Box - $60
Air filter needs replacing
R33 Washer Bottle - $20
Comes with motor
HKS 2530 turbo for sale
Bolt on power for RB25DET, includes HKS actuator.
Currenty on car and makes good power. Selling due to upgrade.
$1200 ono
PM me with interest
:thumbsup:
Eonon double din dvd / cd / mp3 head unit.
Upgraded thinking it was faulty, but it and was a loose earth works flawlessly, my loss your gain. $180 ono
(Head unit and loom only, came with my car so no other accessories came with it)
r34 GTT console plastic in excellent condition $150 ono
any one want a cheap laptop?
it was a gift from my ex so i dont care about fixing it.... will sell cheap!
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=220712058487&ssPageName=STRK:MESELX:IT
Greddy WJ-36 Radiator Hose Temperature Sensor Adaptor - $50 - pmed
Comes with piping
Comes with motor
you sir have a pm
Greddy WJ-36 Radiator Hose Temperature Sensor Adaptor - $50 - ON HOLD
Comes with piping
Comes with motor
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
