Items for sale, out of the car and ready! Some pictures at the bottom.
R33 s1 RB25 motor, comp test: 145 150 150 145 155 150 comes with computer loom and aftermarket coilpacks, no manifolds, very healthy motor - $1500 make an offer
R33 s2 manual gearbox 85,000km old, smooth, can do as a manual conversion kit $1800 (everything you need but no clutch) or alone $1500
ORC (Ogura Racing Clutch) 409 series single plate, couple track days old however Ive never driven on it so I dont know condition, un-sprung center and stock pedal feel - $400 (what it owes me)
R33 9 point Cusco D1 cage, side intrusion bars, through dash, all plates and bolts included - $950
AM performance R33 - GTS/GTST/GTR exhaust, comes with de-cat, split 2.5" system in to in built resonators and 4" twin pipes out with titanium tips - $1000
R32 GTR Intercooler - $150
400r R33 side skirts - $120
400r R33 rear bar, been cut out for larger exhaust but can be re-fiber glassed or exhaust shield made to cover (hence price) - $120
R33 genuine plastic front bar, damaged, no cracks in plastic good for drift - $120
R33 genuine front indicator covers and indicators - $80
R33/34 GTR Auto Select Tower Bar
As Topic States:
I have an Auto Select Raised SPL Type Tower Brace to Suit R33 & R34 GTR (Not R32!)
(pretty sure it suits all r33/34 variant as the strut towers are the same...)
Trial fits welcome...
This Auto Select Skyline GT-R strut tower brace is pure porn, its a wide, thick and strong item that substantially increases stability between the upper suspension mounts. This has the effect of keeping alignment setting stable as the body cannot flex under stresses of cornering.
Drivers of cars fitted with these items immediately notice more responsive handling and more direct steering. They also can remove some rattles and squeaks from older vehicles by increasing chassis rigidity.
This Auto Select brace is machined from high grade T6 Aluminium in a single piece for ultimate strength. Light weight is maintained by removing excess aluminium and this also gives a benefit of an improved look with the AS logo machined into the face of the bar. It is now lighter and stronger than before.*
Other company’s bars and braces are of no comparison. This one is the best available.
The Auto Select Bar wraps around the strut towers for extra support. Thats why the Nagisa Auto R34 Demo car also uses this Auto Select Bar.
Selling as i would like to purchase an R32 GTR Item new as these are very rarely offered secondhand.
Price: $725 Pick Up. $750 Delivered
(Over $1100 outlayed for this originally & will again to get one to suit my R32 GTR).
(Check Below Site for New Price)
http://www.neweraparts.com/Default.aspx?tabid=54&List=0&ProductID=892
Actual Pics (On my R32 GTR to show why i cant reuse this item).
In case anyone think you can just reverse it 180degree amd make it fit...
Nope...It Doesnt work!!!
The angle of the Coilover Mounts are out by about 35ish degrees...
Moreso than that, the brace mounts are moulded around (actually wrap around) the top of the strut towers...
Below is a pic of the Centre Bar & the 2 different types of mounts, R33/R34 (Left) & R32 (Right).
(shows difference in angle & tower mould...
Underside shot showing tower moulding...
Motivational pics:
Contact: PM
Edited by krayzie32
17x8 Drift R's for sale.
Good condition
Good tyres, only fitted a few months ago, 2x sumitomo zII & 1x Maxxis MA-V1 & 1 random due to puncture in other maxxis
Some gutter rash but overall good condition
After $500.
FOR SALE
custom lobster back rb26 twin turbo pipes
lightly polished aliminium 60mm pipe
increases torque and response, reduces back pressure in in the cooler pipes
made to fit 34 gtr but should fit any rb26
pipes are as is, dont come with silicone joiners
after $400, will fit them at no cost but need joiners
post-9995-0-97881100-1333146607_thumb.jpgpost-9995-0-04491200-1333146800_thumb.jpgpost-9995-0-61878300-1333146816_thumb.jpg
R33 s2 headlights excellent condition all brackets no fade etc - $350
33 s2 1997 gtst rear cradle with diff, complete rear hubs n brakes and manual tailshaft - $350
s2 KR4 both Doors with full trim/glass/mirros but missing power window switch - excellent condition, also kr4 boot with s2 spoiler - $500 the lot will throw in some freebies.
Also have a complete s1 gtst head with most boltons still attached.
Edited by KISIN
Update:
R33 s1 RB25 motor, comp test: 145 150 150 145 155 150 comes with std. computer and aftermarket coilpacks, no manifolds or loom, very healthy motor - $1500 $1300
R33 9 point Cusco D1 cage, side intrusion bars, through dash, all plates and bolts included - $950 sold
AM performance R33 - GTS/GTST/GTR exhaust, comes with de-cat, split 2.5" system in to in built resonators and 4" twin pipes out with titanium tips - $1000 $950
R33 gtr genuine plastic front bar, damaged, no cracks in plastic good for drift - $120 on hold
R33 gtr genuine front indicator covers and indicators - $80 on hold
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
