moving house so keen on getting rid of all this stuff
not asking for big bucks just want em gone
mainly just want a few $ for the catch can as it cost me like 80 or 90 bucks i think
catch can - 50
can put a filter on top, or do whatever with it
other stuff
boss kit dont know if universal or whatever, fit my 33 with a nismo wheel
rb25 valley cover
4 floor mats, i think two are from a gtr and two are from a gtst
all the air con stuff from a 32 gtst
carbon canister and the lines
rb20 cam covers (no timing belt cover or valley)
rb20 clutch fan
r32 gtr weathershields id assume fit gtsts
r33 gtst door cards i think when i last looked in decent condition
R33 door used to be white needs to be sprayed but still got stuff inside it like glass etc... think it has the mirror in white too
most things can go for free just ask
pics if wanted PM me
heres a couple
For sale rx4 4 door/ 929 coupe package deal
$8500 ono
1974 rx4 4door flat nose model
The good.
Mark mills built 13bt mild port
s6 rotors 2mm scr seals
s5 turbo
microtech lt 10
Bosch coil pack
3"dump ,exhaust hooker muffler
PWR radiator
PWR intercooler
spl thermo
s4 gear box /rx4 bell housing H/D organic clutch
bosch 044 carter pre pump and surge tank
also comes with 700cc sard injectors not in car
16" wantabee rims
car made around 185rwkw on 6-8 psi engine has done less than 10000 since rebuilt and never boosted
the bad the body is rusty and but still registred and defect free
Thegood complete 929 coupe rolling shell just minus engine has rx4 flat nose front end conversion in primer very straight both cars as i bought them very sad to see them go but baby n.o. 3 on the way not much time for so many projects.
So some of them have to go i suppose.pls pm can txt pics
bump
For sale D1 Drift seats brand new, only 2 days old.
Was going to put them in my 34 GTT but can find seat rails to match
and not paying 500 big ones for custom ones, (thats each).
$500 for both, they are black and grey in colour,
They came will universal rails so come take them as well.
PM me if you are keen
Need them gone asap so i can get newish standard ones
Pics if you need them.
19x8.5" +35 speedy cheetah
5x114.3 suit ford/nissan/toyota.
Bought for my BA XR6T but have decided to put money to new FMIC & Tune rather than looks.
Good condition, some gutter rash but only 1-2cm marks Selling as bought, boxed and ready to go
$690ono
Need this stuff gone! make an offer on anything.
Stainless steel top mount manifold suit rb20/25
MTX jackhammer 12" 250wrms in ported box
kicker 400wrms mono block amp
standard rb25 turbo
50mm external wastegate (4 bolt flange)
intercooler piping suit rb25 with standard position turbo and crossover
2x 14" steelies with good tread suit honda
dell 24" full HD pc monitor, hdmi etc.
PM if you're interested :) cheers
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
Carbon canister?
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
How'd they look on the GTR when you had it?
Stainless steel top mount manifold suit rb20/25 with 2 bolt 38mm wastegate flange (BRAND NEW) $200
Stainless steel top mount manifold suit rb20/25 with 4 bolt 50mm wastegate flange (USED) $300
MTX jackhammer 12" 250wrms in ported box $100
kicker 400wrms mono block amp $100
standard rb25 turbo $125
standard S1 RB25DET coil-packs $30
50mm external wastegate (4 bolt flange) $40
intercooler piping suit rb25 with standard position turbo and crossover $50
2x 14" 4x100 steelies with good tread suit honda $30
Open to offers guys, need this stuff gone. All in good working order.
Pics on request.
PM if you're interested or txt me on 0425366582 :) cheers
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
Real Garrett GT3071R, good condition, next to no shaft play. Rear blades are mint, front blades have some very small chips in a couple of blades but doesn't affect the performance of it. Came with a car I bought but doesn't suit my needs. Already off and ready to go, can throw in a stangard manifold with a spacer welded to it to suit the turbo but will need something sorted out to run an ex gate.
Garrett GT3071R CHRA
(Product Code: 700177-5023)
Description:
Turbo Charger model
GT3071R
CHRA
700177-5023
Compressor Wheel Inducer Size (mm)
53.13
Compressor Wheel Trim
56
Turbine Wheel Exducer Size (mm)
54.98
Turbine wheel Trim
84
$850 ono
May swap for R32 suspension parts (except coiloves), oil cooler set up, or just something of interest.
Edited by Import S13
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
