Straight pipes, twin 3". $80
Jap brand 3" cannon, has mount for R32 which it came off of. $50
Drivers side fixed low rail (has adjustments though) Came off a Bride Stradia in a R32, but will fit other cars. $100
gktech 4x114.3 15>30mm spacers, trial fitted only. These: http://www.gktech.com/index.php/4x114-3-spacers-15mm-30mm-8-piece-set.html $100
Garage 7 R31 Roll Centre Adjustors 30mm, brand new still, comes with high tensile bolts. $150
RB20DET gearbox, 2nd gear syncro not the best on hard shifts, other than that the gearbox is fine. 134,XXXks on the box always used Redline gearbox oil. Only pulled out a month ago, make an offer
Nismo RB20 short shifter. $100
RB25 "Quick Shifter" 25% less gear throw whereas a normal short shifter is only 10%, very notable difference, comes with solid shifter bush. $100
Kicker sub and amp in a proper kicker ported box, plus full Kicker wiring kit. $250.
Some random brand podfilter with heat shield, think it's a 4", brand new unused. $20
Swing me a PM/text for pictures 0431308647.
Located in Mount Barker, South Australia.
Will post if paid for by you.
2002 Kawasaki ZX6r, Great condition, well maintained, 41,000kms. New brake pads fitted recently, new Yuasa battery (old cheapy failed), new fork seals done around 6months ago. Lots of tyre left (<12mnths old)
$5,300 neg.
Got a heap of parts in the shed i need to clear out
S13/180SX - STOCK
stock front pipe - $30
stock dump pipe with oxy sensor - $50
4 stud hubs with good bearings - $10ea
sr turbo front brakes with disks and pads - $100
Hicas power steering resivour with level sensor - $50
Hicas subframe with all Hicas lines, senders, lower control arms, disks & knuckles - $150
AC condensor with lines - $30
AC compressor with idler and brackets - $50
R180 diff (suit 5x1 half shafts) - $100
half shafts (5x1) - $50ea
interior fan and heater core - $15
AC interor core - $15
hicas PS pump - $50
T25 turbo on standard manifold - $150
clutch fan shroud - $35
stock intercooler with piping & BOV - $50
charcol canister - $5
standard suspension arms - $20ea
most interior parts available
AFTERMARKET
Blitz aluminium mandrel bent piping to suit front mount - $150
3" front dump pipe (mandrel bent, mild steel) with oxy sensor - $50
C34 STAGEA
wrecking a c34 stagea (no gbx, motor, suspension or brakes), if any parts u want aren't listed let me know as i probably have it
front nismo shocks and springs - $150
rear standard shocks and springs $100
interor fan with heater core - $15
AC interior core - $15
front seats - $50ea
door shells - $30ea
rear hatch shell - $40
roof rack - $30
passenger side rear hatch glass - $50
dash - $50
carpet (minus hatch area) - $15
headliner - $15
visors - $5ea
rear seats (top section only) - $40
steering wheel (with radio controls) no centre - $40
auto shifter - $25
wiper and indicator stalk assemblies - $30ea
front & rear seat belts - $30ea (or the lot for $120)
front driveshafts (drivers side needs repair) - $30
front AWD knuckles - $30ea
ABS unit - $30
front X-member - $30
rad overflow bottle (good condition) - $25
UNIVERSAL
5x114.3 space saver spares - $25ea
floor mats - $5 set
For sale various r33 parts not sure if series 1 or 2 and the condition given to me by previous owner of my car.
Washer bottle 20
Silver rear lights 60 pair 30 ea
Stock intercooler 15
Ecu pretty sure its auto 60
Washer bottle no holes 40
Power window motor unknown condition 40post-109033-0-98294800-1365847817_thumb.jpgpost-109033-0-44828800-1365847835_thumb.jpgpost-109033-0-21954400-1365847853_thumb.jpgpost-109033-0-81831900-1365847870_thumb.jpgpost-109033-0-31891100-1365847896_thumb.jpgpost-109033-0-73669800-1365847913_thumb.jpg
A few items for sale. All parts are from R33 series 2
Brand new r33 Apexi Power Fc with hand controller still in box. (Manual) Never got around to fitting it just been sitting in the cupboard. $1400
R33 HKS adjustable actuator, bought from a member on here a few years ago but never fitted also. $75
R33 series 2 front bar with nismo lip (Kr4 silver in colour) $350
R33 series 2 bonnet (Kr4 Silver) $350
R33 series 2 rear bar $100. SOLD
R33 series 2 spoiler $75
R33 crossover pipe $50
Everything is in great to immaculate condition.
Not on here alot so prefer phone contact, If i dont answer im at work just sent me a txt.
Cheers Brad 0409699742
For sale is a Set of 4 rims they are the original japan drift teck with heaps of Dish. made In Japan
Fronts are 18x9 15 offset
Rear are 18x10 20 offset
5x114.3
Just had a full respray in KH3 black
Can give brand new tyres Achilles 123s for $2000 or $1,500 with out tyres
Thanks.
$16,500
Willing to accept stupid offers (Dont be silly though) wont be offended, no work = cant pay repayments.
Mods: 1000km ago car underwent major service replaced all oils and fluids, engine, diffs, brakes, trans, coolant with motul fluids, all done at Japanese Motorsport. Car is ready to go for new owner. 240rwkw running on almost stock boost. Tuner advised easy 300rwkw with bigger injectors.
Engine:
- Forged Engine
- R34 GTR N1 Turbos
- N1 Oil Pump
- Nismo Fuel Pump
- Nismo thermostat
- Pod Filters
- Tomei adjustable cam gears
- HKS 3" front/dumps into custom 4" exhaust
Exterior:
- Spoiler removed and holes welded
- Black 17 Enkei RP01 Wheels and new 235 tires
Interior:
- R34 GTR Vspec Seats, mint.
- Sparco suede steering wheel
- Pioneer headunit
- Soundstream 6" front speakers and 6x9" rear
Have brand new Greddy oil catch can and Apexi Power FC and EL hand controller ready to install worth $1500 alone.
Can provide more detailed pictures if required, no test pilots, welcome for me to take you for a test drive if serious.
Items:
R33 4 stud space saver spare tire, Never used. $30
Stock R33 front and rear sway bars $20 each
2 x 235/45/R17 firestone tires, camber wear, one has a nail in it. easy repair, 4-5mm tread left. $20 for the pair
R33 air intake snorcle $10
R33 series 1 ignitor pack $15
12 inch moulded sub box for the drivers side of the boot, covered in grey carpet. $50
R33 series 1 non turbo ECU $40
R33 series one wing ( LED brake light doesnt work) $40
R33 power steering tank $15
R33 cam seal x1 new
R33 stock cam cover $20
R33 stock coil pack cover $20
R33 charcol canister $5
R33 battery - holds charge, good condition $30
R33 window washer bottle - no pumps included $5
R33 rear cabin vent - the one in the drivers side rear fender $5
Contact Details:
PM me.
For sale
RB Apexi copper radiator with apexi radiator cap, good condition. $200
RB25 fan. $30
Twin au thermo fans. $20
Shit I need that we can make deals for-------
S13 radiator over flow tank
Catch can
S13 30 mm rear over fenders
Pm me for any details etc
R33 Series 2 skyline GTS-T Immaculate condition for its age, possibly on of the cleanest in SA
95,000kms. Only done 40,00kms in the last 8 years
Only australian owner
Only selling as i dont drive it that much anymore and would like to buy a boat.
Contact Brad 0409699742
$14,000 open to offers
All details are on carsales link below.
http://www.carsales.com.au/private/details/nissan-skyline-1996-14598191?base=1216&vertical=Car&cr=45&page=4&eapi=2&__N=1246 1252 1247 1282 4294963846 4294963593 901 1216&num=15&silo=Stock&sort=default
For sale: greddy profec b spec ii black electronic boost controller
Perfect condition in box with solenoid, hoses and all wiring.
$250
can post at buyers expense
Please text Lucas
0413733433
Located Adelaide southern suburbs but travel to eastern Adelaide often for work
Cheers
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
