Hi,I have a 1998 Nissan Skyline R34 GT-T with automatic transmission.
It has podfilter,front mount intercooler and turbo running at 11PSI.It probably makes around 190kWs-200kWs at the wheels.
Just curious,how come I find it very hard to do wheel spin or burnout ? Say from a dead stop,I floor or push the accelerator all the way down and no wheel spin at all ?
Is it because of the traction control is on or not enough power to make the rear wheels spin ?
Thanks !
https://www.sau.com.au/forums/topic/354239-r34-gt-t/
Have you put it on a dyno? With a pod, exhaust, fmic, fuel pump, splitfires, 8psi mine only made 140rwkw. They hit r&r really bad when they see unexpected airflow (more boost)
It probably won't be making near 200rwkw without a tune.
What wheels/tyres are you running?
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5674414
Traction control on my R34 makes it very difficult to get wheel spin unless you really try (and when you do, it immediately cuts the second butterfly and kills the fun). Have you tried turning it off?
As an aside, I'd also think your auto gearbox will make it more difficult to spin the wheels.
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5674523
Nope,haven't been to the dyno yet.Well,that's what the previous seller told me but anyways.
Yeah I did try turning off the traction control but still no luck.Maybe you're right the automatic gearbox isn't as responsive as a manual.
What do you mean by "they hit r and r really bad when they see unexpected airflow" ? I'm running the stock wheels,225/45 ZR17 for both front and rear.
How about you "jrm" ? Is your car manual or automatic too ? What do you mean "and when you do,it immediately cuts the second butterfly and kills the fun" ? Lol,sorry I don't get it.
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5675586
Mine was making 182rwkw with just k&n panel filter, FMIC & 3" exhaust - running basically factory boost (up to 8psi dropping down by redline). I'm now running a 10psi actuator, nismo fuel pump, new spark plugs, new coilpacks - so I'd expect maybe 190rwkw - but I'll be getting it properly tuned soon. I've never heard of anyone breaking 200rwkw without a tune.
I wouldn't even bother trying with the traction control on. To explain what I mean by my comment - the traction control on the R34 utilises two systems - one to cut spark, and the other has a second throttle butterfly that basically closes off (think how your accelerator pedal opens one butterfly - well this one sits in front of it - so no matter how hard you have your foot pressed down, TCS has shut you down).
My car is manual, but to further explain what I meant, if I were to be in a situation where I accelerated too quickly off the line in the dry, with traction control on - I'll get just a small hint of wheel spin before the traction control kicks in (closes that second butterfly) and stops my accelerator pedal being useful, cutting the boost off, and stopping that wheel spin (aka 'fun'). With traction control off, it'll wheel spin trivially with too much accelerator and traction control will not kick in.
You should be able to tell whether traction control is kicking in and stopping your fun - the 'SLIP' light in the dash will flash. Additionally, if TCS is off, the 'TCS' lamp should be lit in the dash.
And yes - it's possible that the ECU could be working in conjunction with the TCS system to make it even harder to wheel spin - BUT I havent driven or owned an R34 auto, so I can't comment here at all (I've never owned an auto, and will never own an auto..)
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5675641
Some skylines manage to get power, others don't.
R&R is rich and retard which is basically a safety mode to protect the engine when abnormal things happen (eg. More boost/airflow, knock)
When this happens your cars power will suffer.
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5675901
This R&R you speak of...will an untuned car do it on a daily basis?
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5676997
Sorry but what's R & R ?
R&R = Rich & Retard.
To explain:
'Rich' - enrichen the fuel mixture
'Retard' - retard the timing
R&R is a one ECU strategy to try and protect the engine, another is 'air flow cut'. To copy/paste from another thread:
1. Rich and retard is triggered by excessive cylinder knock only. When knock level threshold is exceeded the ECU richens AFR and retards igntion. Once R&R has been triggered the ECU then will attempt to reinstate AFR and ignition advance back to normal until it detects knock again. It is designed to protect engine against bad or incorrect fuel and internet mechanics.
2. Air flow cut is triggered when AFM voltage exceeding threshold voltage. Air flow cut starts at 4000rpm and threshold increases as a function of rpm up to about 5000 rpm. When it triggers, it cuts fuel and ignition...It is designed to protect against boost control failure...overboosting from broken WG actuator etc...also provides protection against internet mechanics...
I would judge in most situations with an untuned ECU and higher than factory boost you're more likely to be seeing 'air flow cut' than R&R. An untuned ECU will in with the airflow cut anytime it sees too much airflow - if you're running too much boost, then it could do this anytime it sees that too much boost. This could easily happen at more than 10-11psi, and possibly during cold weather even at those levels (where the air is more dense).
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5677034
To explain:
R&R is an ECU strategy to try and protect the engine in over-airflow situation; These situations would arise when you run too much boost for the factory ECU tuning to cope with - and it resorts into the protection mode. I've seen this on my R34 when I attempted to push more than 12psi - the car just feels like it stops, hits a brick wall, has no power at all - and then will pick up again a few seconds later when the airflow has dropped. There are plenty of threads with information on R&R - if you want to know more, I suggest you use the search function.
So yes - an untuned ECU will do this anytime it sees too much airflow - if you're running too much boost, then it could do this anytime it sees that too much boost - which may change depending on atmospheric conditions (think primarily hot/cold weather which change air flow situations)
Yeah ok so it's the same as engine breakdown when you max out your boost.
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5677052
  • 4 weeks later...
Anyways,doesn't car accelerates faster without wheel spin ? I mean if you have too much wheel spin in the beginning and lose traction,your car will accelerate slower due to the couple seconds
you lose at the start ?
https://www.sau.com.au/forums/topic/354239-r34-gt-t/#findComment-5717152
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
