  • Replies 99
but you have NEVER seen it in action howcan you say it is not worth it?? what if you put it in and your car picks up .5 of a sec down the 1/4??? i know heaps of ppl that have spent alot more than that to make up simular resaults....
as i said ppl with ANY controller come try it out and compare
sewid...
"Gas filled what? A valve like this works using a spring and a diaphragm. Are you thinking we're all complete morons or something?"
No, do some homework, and then come install this in your car and call me an idiot if it goes the same...
This is coming from a guy that says "using gas ... keeps the temps cooler inside the valve"... Yeah you're a real expert. :rofl::P
No wonder this thing improved your performance, you were using a hairbrush as a bleed valve before.
If its not simply a spring/diaphragm device and actually uses gas, the gas sure isn't there for keeping the temperature down.
Dude you are an idiot.
"Gas keeps the temps inside the valve down"? Are you a complete imbecile and believe your own BS? What relevance does the temperature of a bleed valve have to anything.
Go and crawl back under the rock from whence you came little man.
Sewid you really need to do some research befor making comments like this....it may save you from presenting as a complete twit.
Ok,
At the end of the day, there just isnt enough facts supporting this 'very special boost controller'
This is a small world, and something thats this good would travell in no time, and a week after it came out, it would be used everywhere and be as common as a bogan in an old commonwhore.
Ive been into imports and turbos specifically for a few years now, i own one myself, know people that own turbos and have done a fair bit of work on turbos.. and i must say, in all that time ive never heard or seen of this 'very special boost controller'
Now if it came out as part of the Audi's or whatever, then surely major workshops etc would know about it, and be using it?
why arent they?
'Tis a scientific world we live in, without proof, im just not sold, sorry
the gas is used because when you push more power/boost air temp inside the turbo raise correct??? ok let go back to year 7 science.... what happens to air particals when they heat up.... thats right they expand (see where this is going here)... when it expands the air becomes thinner (looses viscosity) ...would i be correct in saying alot of boost controllers start slowly raising the boost (higher boost in taller gears sound familier???) now what if that air is cooled when comes into the valve .... shall i keep going????
reson for em not getting around yet is that they have been under developement for ages getting the porting gas type ect correct and consistant
Guest INASNT
when u raise the boost the boosted air isent going into the pressure pipe that controls the wastegate opening and closing. The amount of thermal transfer going from the turbo to the wastegate to the rubber hose to the boost controller is so minimal in a 1/4 run, the gas would not do shit to make u do any quicker 1/4 time.
listen. Can i get a accurate answer to this question. Will this super doopa pneamatic valve do a better job than my APexi AVCR?
Im using the apexi to limit wheelspin in 1st gear. That alone is reason enough to leave it there.
mx83toy whats your answer to that?
Huh?
I've pulled apart valves like this many times myself. im yet to see one that isnt built like that.
My guess is it would do just as good if not better than the Apexi in terms of control of the set boost. it does not have any of the extra functions of the electronic boosters except to control "how the boost comes on"
ps Hope to find out for myself towards the end of the month.
Look I admit i might be wrong about EVERY relief valve being built using springs/diaphragms because i cant say ive looked at lots of different valves from every manufacturer. I have looked at many and pulled them apart to find that mostly they look the same inside.
But your attempt at explaining why gas is used here is technically flawed and completely wrong.
1) This valve is small, it has no cooling mechanism (compressor, radiator, etc)
2) Cooling air quickly requires a lot of effort and a lot more hardware than this valve provides. This is what we all get bigger and better intercoolers for.
3) Whatever gas they put in this valve is not immune to the laws of thermodynamics.
4) Ergo the gas will heat up to ambient or higher temperature before the car even starts up. The gas will then reach the same temperature as the air passing thru the valve quite quickly.
Even if the gas is stored compressed it is not going to be any cooler than ambient temperature. Only the expansion of that gas will result in any cooling effect. Of course the expansion of the gas means the gas has to go somewhere, into the atmosphere probably? And if not into the atmosphere it will need to be recompressed to perform the useful cooling work again. I dont see a compressor attached to this very special boost controller.
look man i didnt invent the thing....to my understanding this is one of the functions of the gass.... i've gone alot faster with it compared to other controllers full stop. you want to try one out, cool come down,
you want to bag it out come up with something better yourself, and then prove its better else...
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
