engine sold
now have the rest of the car to part out.
radiator $20
pedders xacoilovers $1000
gtr strut braces $100 for fron t and rear
series 2 interior $150
Isotta drivers seat $300
shimmed lsd $150
passenger door $100
drivers door with minor dent $20
rear screen $50
hicas lock bar $40 SOLD
rear camber adjustable arms $20 DAMAGED
rear brakes $150
400r front bar $200 SOLD
400r side skirt $50 SOLD
bootlid with gtr spoiler slightly damaged $50 SOLD SPOILER
airbag steering wheel $50
pioneer cd player $100
5 speed gearbox conversion kit complete with pedal box clutch flywheel etc $1500
alternator rebuilt 100kms ago $75
series 2 left hand head light $150
left hand tail light $30
front left hand guard $50
Clear front indicators $35
Front mount intercooler 100mm with brackets to fit $120
Boot lid $30
Turbosmart plumb back bov $120
Turbosmart Fuel pressure regulator $150
Bosch 040 or 044 (whichever flows more) with surge tank to go under rear guard $150
Air bag steering wheel $50
rs exhaust $50
I need three spacesaver wheels will swap for parts
Phone or sms only 0421347934
Seaford Rise South Australia
https://www.sau.com.au/forums/topic/354539-1996-series-2-r33-wrecking/
  • Replies 40
Posted Images
Hey mate, do you have the boot trims? It's mainly the section covering the battery that im after, but im willing to take all?
Postage to sydney too?
Thanks
Its not the best condition it is all chopped up to fit around an aftermarket strut brace and the other stuff has rips, not worth having I think.
cheers mat
engine sold
radiator $20
series 2 interior $150 SOLD
Isotta drivers seat $300 SOLD
shimmed lsd $150
passenger door $100 SOLD
drivers door with minor dent $20 SOLD
rear screen $50 SOLD
rear brakes $150SOLD
airbag steering wheel $50 SOLD
left hand tail light $30 SOLD
front left hand guard $50 SOLD
Clear front indicators $35 SOLD
Boot lid $30 SOLD
Bosch 040 or 044 (whichever flows more) with surge tank to go under rear guard $150 SOLD
Air bag steering wheel $50 SOLD
rs exhaust $50 SOLD
I need three spacesaver wheels will swap for parts SOLD
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
