Way too hard, the ATESSA system is rather complex with wiring and pumps and sensors etc.
Cheaper and easier to buy a GTS4.
Yeah I thought as much, I prefer RWD but it would be nice to have the option to switch for 1/4 mile runs and the like ay.
  • Like 1
  • Nope 7
Its another one of those Buy a GTR scenarios.
The amount you'd be looking at to convert a gtst to 4wd would be near to the point where you could sell your current vehicle, then buy a GTR with the remaining cash u would spend on the conversion.
GTS4's arnt all that expensive these days anyway.
  • Like 3
As above - the ATTESSA system is extremely complex. Just the ECU side alone is a headf*k. Plus not many people know too much about it to be able to offer advise when you're half way through it so you'd be stuck if you started it and couldn't finish. GTS4 or GTR :thumbsup:
  • Like 3
  • Nope 1
Yeah I think ultimately I'll hold onto my R32 GTST and eventually buy an R32 GTR. GTST will become the track/daily drive, GTR will be the weekender.
  • Like 1
  • Nope 5
you would need:
AWD gearbox (~$1000)
Front sump and diff from an rb26 ($400)
A custom adaptor plate to bolt the 26 sump onto the 25/20 block. (approx $800-1000)
G sensors (~$1000 new, hard to find at wreckers)
Front drive shafts ($?)
Attessa ECU ($?)
Attessa Pump ($?)
Wiring loom for Attessa ($?)
and probably about 20-30 hours labour @ ~$100 p.h...
  • Like 2
Sounds like a good plan to me :)
I'm planning to pick up a 32 gtst at some stage in the future for a track build. Would love to track the GTR but im not made of that soft of money :)
  • Like 2
dont gts4's come with all awd??
it would be a much cheaper option then trying to convert.
you would need:
Attessa ECU ($?)
Attessa Pump ($?)
yes. thats what the name would suggest.
i couldnt agree more that its a waste of time and money. very much a "buy a gtr/gts4" scenario as it would be miles cheaper and prevent you from trying to top yourself from the stress of working it out.
that said, i have seen it done before here in christchurch. it was for sale a while back. i didnt bother asking how much time and money it took.. didnt want to know.
if you mainly use rwd and would only use 4wd once in a blue moon then would it be worth the permanent weight penalty of 100-150kg?
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
