OK Sports fans, here it is.
Team LunchDate's first official meet thread. I am not interested in making a booking or collating numbers, so I dont really care if you notify your intention to attend or not, this thread is just here to make sure everyone is informed of when/where/what etc and the details dont get lost inside the whorethread, as usually is the case.
First up, let me stipulate that EVERYONE is welcome, regulars, n00bs, lurkers etc etc. We are a pretty laid back bunch of people and this is just about catching up, meeting and greeting and possibly putting some faces to names.
Friday 5th March 7am
Cafe Wotsisname
Cloisters Arcade
Perth
(pretty good range, and awesome prices. Fully cooked brekkie starts @ $10, and best of all, just down the hall from LowDown, possibly Perths greatest coffee)
If you are coming from anywhere in the CBD, the RED Cat bus stops right outside the front doors. For those driving in for the auspicious occasion, closest parking will be Mis Majestys Car Park, on Hay St.
I hope to see as many of you there as possible.
https://www.sau.com.au/forums/topic/355067-team-lunchdate/
  • Replies 216
:blush:
yer, its the 4th, not the 5th. This thread was smashed out at high speed in between narcolepsy inducing project meetings, so if anyone finds any further inaccuracies...
Well, you can lick the cheese from the underside of my one eyed one horned blue veined custard chucker.
https://www.sau.com.au/forums/topic/355067-team-lunchdate/#findComment-5687454
I miss catch up mandate.
Even if it was only one time.
We miss you too, sweetcheeks. Maybe we can get bubba to glue some carpet to his back and we can all pretend....
I actually feel a bit sick...
Probably best you dont order the scrambled eggs then.....
https://www.sau.com.au/forums/topic/355067-team-lunchdate/#findComment-5687920
  • 2 months later...
So, its about time we all got off our collective asses and did this again eh?
I am proposing the date of Friday the 13th of May, mostly because it will be my last day at my current position and I will feel justified in rocking up late, fat and happy :P
I am keen for same place/time (7am, Cafe Wotziname, Cloisters Arcade) but if anyone has anywhere else they would like to try, then run it up the flag pole and we will see who salutes eh?
As before, this is open to ALL, so feel free to come put some names to faces all you n00bs out there.
https://www.sau.com.au/forums/topic/355067-team-lunchdate/#findComment-5781947
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
