OK Sports fans, here it is.
Team LunchDate's first official meet thread. I am not interested in making a booking or collating numbers, so I dont really care if you notify your intention to attend or not, this thread is just here to make sure everyone is informed of when/where/what etc and the details dont get lost inside the whorethread, as usually is the case.
First up, let me stipulate that EVERYONE is welcome, regulars, n00bs, lurkers etc etc. We are a pretty laid back bunch of people and this is just about catching up, meeting and greeting and possibly putting some faces to names.
Friday 5th March 7am
Cafe Wotsisname
Cloisters Arcade
Perth
(pretty good range, and awesome prices. Fully cooked brekkie starts @ $10, and best of all, just down the hall from LowDown, possibly Perths greatest coffee)
If you are coming from anywhere in the CBD, the RED Cat bus stops right outside the front doors. For those driving in for the auspicious occasion, closest parking will be Mis Majestys Car Park, on Hay St.
I hope to see as many of you there as possible.
https://www.sau.com.au/forums/topic/355067-team-lunchdate/
  • Replies 216
:blush:
yer, its the 4th, not the 5th. This thread was smashed out at high speed in between narcolepsy inducing project meetings, so if anyone finds any further inaccuracies...
Well, you can lick the cheese from the underside of my one eyed one horned blue veined custard chucker.
https://www.sau.com.au/forums/topic/355067-team-lunchdate/#findComment-5687454
I miss catch up mandate.
Even if it was only one time.
We miss you too, sweetcheeks. Maybe we can get bubba to glue some carpet to his back and we can all pretend....
I actually feel a bit sick...
Probably best you dont order the scrambled eggs then.....
https://www.sau.com.au/forums/topic/355067-team-lunchdate/#findComment-5687920
  • 2 months later...
So, its about time we all got off our collective asses and did this again eh?
I am proposing the date of Friday the 13th of May, mostly because it will be my last day at my current position and I will feel justified in rocking up late, fat and happy :P
I am keen for same place/time (7am, Cafe Wotziname, Cloisters Arcade) but if anyone has anywhere else they would like to try, then run it up the flag pole and we will see who salutes eh?
As before, this is open to ALL, so feel free to come put some names to faces all you n00bs out there.
https://www.sau.com.au/forums/topic/355067-team-lunchdate/#findComment-5781947
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
