I am pretty sure your usual friday attire of the mankini and string vest dont really qualify as "pants and shirt" anyway Ross, so you will be fine either way. :thumbsup:
  • Replies 216
Aw man, I have been so busy I kinda forgot all about it! Anywhoo, I am up for a carbo loaded, drain blockage inducing feed this friday morning. Any one else up for it?
Except you Jase - we will expect your apologies soon after, as usual :P
  • 3 weeks later...
Sif have lunch with a woman. Girl cooties FTL
:P
You could always come have breakfast with us! Next one will be -:
Friday 7th October
7am
Kings Hotel
Cnr Pier and Hay Sts Perth
I would love to make it earlier to allow people working outside the city to join in, but the problem is finding a venue that is open for a DECENT breakfast before 7am. Any suggestions will be happily considered.
  • 3 weeks later...
I am not going to make it to this months breakfast :(
Flat out at work, and overwhelming home responsibilities have finally won over. Plus, the fact that I will catch up with most of youse tomorrow night @ sinmworld, so anyone thats going - have an extra strip of bacon for me :thumbsup:
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
