  • Replies 216
Big thanks to everyone that turned up this morning. Was a great turnout for the last feast of the year. We will leave the next one until the first Friday in February 2012, to allow paul to go on holidays.
And for those of you thinking about just turning up - just do it!
Until next year, fellow breakfasters - remember
the arteries are evil and must be punished :P
  • 1 month later...
It will def be on, even if its just me eating all the bacon, and pretty much everyone that attends has work on, thats why we have it early.
So now Phil and you have no excuse, other than laziness and apathy!
touche
Is that this friday? give details.
They sound like pretty good excuses to me!
FYI best place to park nearby for about an hour if I decide to make the holy pligremage?
come down hay st from the east end, and pretty much anywhere along the road side. Meters etc dont cut in untill 8am and we always manage to find a park close by pretty easy
Tab.....
Aaallrighty then bitches, bitchettes and Paul
Its that time of the month. Same bat time, same bat place. Who is gonna come and bask in my radiant glory.
7am
Kings Hotel
Cnr Pier and Hay st Perth
$17.50 for all you can eat - but only if you get to the bacon before El presidente
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
