Ive seen alot of drift buttons for silvias, etc but not for skylines. Are they available or is there a reason why not. What should I do about handbrake drift button for my R33?
thanks
Go hydraulic handbrake, you'll never look back
Save ur money and dont buy a drift button
Pull the cover off the handle of the handbrake lever. Get a small screw driver and pry out The 2 tabs holding the spring up. Doing this will release the button and then u have a drift handbrake.
Then when ever u want the button to lock just pull the button out with ur fingers
DVS32R's way seems a bit of a pain, just in that I drive the car far too often on the road Vs drifting, so i might just do the old 10c piece taped on trick
. I know Cusco has a handle and button replacement kit, but that goes for almost $100 and doesnt look that great either. Apparently normal ones dont really fit. Anyone know of products that do?
(Why not just tape the button "IN" with duct tape. When you are finished drifting, remove the tape, and you have a normal handbrake.
that would be the afore mentioned 10c piece trick
Edited by ausdrift
I just don't understand what you want. You clearly don't want the normal drift button that is available at the imports parts stores. You don't want to modify your standard handbrake which is the exact same thing as the aftermarket button attachment except it's free. You don't want to spend $100 on the handle and button replacement from cusco. The tape doesn't tickle your fancy....
So there is no pleasing you then?
  • Like 2
Funny enough there are these fantastic inventions called thumbs.
You know, keep the thumb on the button as you pull it up, the lever will go down when you release it.
Too difficult? Then try this:
Push the button in and hold it with duct tape (or whatever your preferred method).
Drill a hole through the handle into the button (drom the top). Hole should be big enough to allow you to put a screw into the hole - to act as a dowel
Keep screw in glovebox (or on a piece of string attached to the handbrake lever)
When you want to drift, push in the button and insert screw to hold the button in there. Note screw should be tight enough int eh hole that it will hold itself in place, but generally the button spring will hold anything you put in there in place.
I've had this mod on two of my forest drift cars (rally cars to normal people) and it works fine.
Yes, the hyd handbrake works well, but if your stock handbrake is up to the task, then there's no reason not to use it.
Elite Racing - The normal drift button from stores isnt available for Skylines otherwise I would snap it up, the tape fix is just a bit too povo for any kind of perminant solution and the Cusco part is ugly.
So yeah, still looking for a solution
Too pov? For drifting? What the fuck. The motorsport second only to destruction derby in terms of absolute buckets of shit being driven into the ground...
Drifting is judged on angle, entry speed and acrobatics - not how cool your interior looks. Focus on the important stuff!
There is no making you happy.
There's your cheap and easy drift button.
Stop being such a princess.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
