Hi Guys,
How are we?? Firstly i need to know what is this HICAS stands for and what it actually do??? secondly, Just want to know about HICAS light ....... Since i changed my factory steering wheel to after market steering wheel, this HICAS light just truns ON whenever it likes but doesn't turn off unless i stop my car and start it after 1 or 2 hours.... if i start my car stright away, light comes ON straight away, and when the light is ON , the steering feels bit heavy........ i don't think that its because of aftermarket steering wheel and Boss Kit.......... Majority of skylines got aftermarket steering wheels............. So what you recommend guys???? any help will be highly appreciated.... thanks :worship:
https://www.sau.com.au/forums/topic/355295-hicas-playing-up/
when you change the steering wheel you must use an aftermarket boss kit to make hicas work
hicas is rear wheel steering over 80km/h
its expecting sensors in the steering wheel to work out where you are turning
without those (no boss kit) it panics and throws an error
THANKS FOR YOUR REPLY MATE, BUT I ALREADY GOT AFTERMARKET BOSS KIT ............
hmm well is it the correct model or setup properly / aligned it?
given it only broke when you changed the steering wheel, id say it might not be correct or something?
have you got the old steeering wheel you can put back on to confirm it works again OK?
hicas is like a cock flovoured lolipop.... totally useless.
get a lock bar :)
Agree with Hamish. whilst I have no idea what a cock flavoured lolipop tastes like, i do recommend you replace the HICAS with a lock bar, this will remove the problem :cheers:
If a big steel bar was better than Hicas, Nissan would have fitted it from factory.
Real drivers feel the change during the corner and appreciate what it does for the handling. Other drivers whine that the car did something they weren't expecting and have a cry.
with only 229kw, i'm sure your 32 GTR is a real animal to handle with all that powahhh :rolleyes:
Haha are u serious, hicas was put there to prevent oversteer and make the car more 'tame', ppl remove it causes its a crap idea, something for ppl who cant drive 'real' cars. Who wants there rear end moving around when they want predictable handling.
Remove it and your problem is solved, best cheap mod you can do.
lol, so every car in the world that doesn't have HICAS is not a real car? If HICAS was better than a big steel bar, Nissan wouldn't have ditched it themselves :)
It's good at what it's supposed to do...but many systems end up faulty, and there is nothing wrong with wanting to drive a car the way you expect it to. For the extra 10kg of dead weight, you're better off with a tube of lightweight steel and handling just like every other RWD car ever made.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
