DONT MISS OUT ON THIS CHANCE TO HAVE TITANIUM ! I currently have this exhaust on my car and im wanting to swap/sell it for a 3.5" JAPANESE Brand Cat back (Stainless) . This exhaust isnt really the sound i am after(Very Raspy/GTR Sound) . I am open to reasonable offers and i can garentee you this exhaust only weighs around 4kg and is very clean (almost new) . Im trying to track down a nice deep sounding stainless exhaust so let me know what you guys have!
If i dont get a trade i will be selling it for $800
https://www.sau.com.au/forums/topic/355498-titanium-exhaust/
Damnit if I had the cash I would buy this for $800 in a second.
If you want a very deep sounding exhaust a recommend a Blitz one. Every single one I have heard (including mine) is very deep (and loud).
So far is a toss up over a Apexi N1 and Trust PE II? I heard you car at dyno day last year Renault one and it was sick ^^
i have a 3.5 in mega n1 currently on my gtr, if your interested we can meet up and trade sounds...
im near the airport, i can meet you half way or something..
call me if you want 0404 301 881
Ive got the same Trust Ti-R system on my car at the moment. The note is awesome. I love that it vibrates the garage door when the car is idling at ~900 rpm. Plenty deep enough a note with a little more displacement. Havent tried setting off carpark alarms yet but I think it could probably do it.
Mine had a 3" flange on it too, but expands out to 90mm/3.5" for the rest of the pipe work. Its straight forward to cut off the titanium flange and change it to a slip fit join so you can link a 3.5" cat to it with no size changes after the cat.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
