Excellant work bobby I commend you.
Thought I'd add I was working for APC in springwood couple years
ago, in which I had the pleasure of working on a Bathurst r31 skyline.
I was told by the owner that during the racing year of 1987 the budget was
3 million dollars. Replacement cost of the exhaust manifold on the car was surprisingly
10 thousand dollars!
Thank you
Was that rod marklands old car the R31 rb20 turbo?
There has been a slight change in this build with cam selection. Previously mentioned we were using IN EX 260 10.25 lift Tomei now we will be using IN 270 10.25 lift EX 260 10.25 Lift still Tomei cams, John has done some further calculations and found this to be the best combination for the motor.
I will get more info on why he has decided on this Intake cam!!
Do you get a cam card with the Tomei camshafts?
If so do you know what the IVO, IVC, EVO and EVC degrees are?
Those figures should actually be decided on by the engine builder. The info they supply (Tomei etc) are for a given lobe centre figure. That why i laugh everytime i read some-one quoting cam sprocket degree adjustsments as cam settings. . Unless you know where the cams are set ie: lobe centres before you start playing with them your just guessing and hoping for the best...
Good to hear your getting close to start up Bobby :thumbsup:
The above pic shows the external oil supply tot he head , No oil will be supplied from the block. We can alos control the amount of oil for the head.
The above video, John has give a light skim of the head, he only took off 2 thou.
Motor is ready for final check and finished off very soon
Huge respect for this build, proven builds are great in practice and economic terms, but there is something to be said about the satisfaction of looking outside the box and creating solutions which push the boundaries. To succeed doing this is to properly achieve something, however just dumping a bunch of cash at a workshop to build your car to 400kw using the same methods that have been used a million times before, is just that, very little has been learned, and in my mind, very little has been achieved.
Thank you for your comment.
Yes its not the money its all about getting it right
We have also changed the headgasket to a 0.9mm Nismo Gt500 gasket from the 1.00 mm cometic, and the final deack height is +4 thou and using the 0.9mm head gasket we can achieve 33 thou squish.
With this quench distance, static compression 10:1 what boost pressure will be achievable to make the power you want?
Squish at 33 thou 10: 1 comp - boost in manifold will be 34psi and in the cylinder i think john said this will become like 15 psi.
In the documents with calculation there is a right about boost pressure.
Bobby, early on you mentioned that John looked at making a custom plenum for this engine... can you go into any detail on what was proposed before you scrapped the idea?
I have been looking at "Lehmann" style plenums recently and wondering if this is what John was considering.
There was a really good thread on the hydridz forums about a 'lehmann' style dual plenum inlet manifold being designed and made for an L28 I think it was. It was a long thread but had alot of drawings and CFD testing done with the guys design, think he got it all CNC machined out of two big chunks of billet in the end. Looked amazing!
Damn you Michael! I want to make one now!
I read it! :)
I want to design one and I want you to make it... I am so time poor it is making me sick.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
