  • Replies 52
Ant really dose have a lot left even with nothing more than rubber.
We had to get this done before anyone else did and ant ran it in as street driven spec still at modest boost and didn't even take the spare out.Expect very much faster times from Ants beast.And its a local built,local tuned car with an ozzie ECU.Wolf.
Well done Ant.
https://www.sau.com.au/forums/topic/35560-nd4spd-runs-10s/#findComment-709688
hey guys
thanks so much...yer its been a long time in the pipe work and i finally got the urge to do it...
good thing is i drive it there...same tyres mind u there the same ones i tried to kill at motorvation,just drove to start line and side stepped but of course the gentle selection into 3rd gear hehe and it even stayed together...must of been my good luck charm hahahahha and i even got to drive it home...hey aidwin hehe see the speedo hahahaha shushhhhh
but yes they banned me lol but drag combat is non andra so ill be there again and hope with a box and hope some decent tyres hahah
now all i can say is time to get dannys and fabs cars goin as there goin to be into the 10s as well...bring on the bannings hahahah
thanks again
https://www.sau.com.au/forums/topic/35560-nd4spd-runs-10s/#findComment-709917
