I dont know if you are on this forum but if you are I hope you read this. The airport business car park is not the smartest place to practice your drifting. This may come as a surprise to some people, but airports generally have really tight security. Believe it or not, aeroplanes cost a lot of money and airlines like to make sure that they don't get damaged. let alone all the terrorist hijackings and sabotage and shit. so it goes without saying that there are CCTV cameras all over the place and people working in the hangars. Then there is the airport security that drives around checking all the locks on doors. Not to mention the worksite security checking up on things. And guess what else. The AFP also do regular patrols of the airport. So breaking into a car park in a fairly secure and monitored place like an airport is not the smartest idea. It doesn't really make us look good and tends to encourage blitzes on performance cars. So use your brain when you want to go and practice sliding your car and do it somewhere that the people that want to catch you aren't.
Rant over
  • Like 1
https://www.sau.com.au/forums/topic/355790-fking-idiots/
Rant over
QFT
https://www.sau.com.au/forums/topic/355790-fking-idiots/#findComment-5694715
pretty sure it was a 200sx. we got a call from airport security asking about it and when we described the car they said that they had seen them before. only this time they pulled rego off of cctv. apparently its 3 grand just for being in the car park without access passes. and car confiscated for 28 days
https://www.sau.com.au/forums/topic/355790-fking-idiots/#findComment-5696722
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
