  • Replies 50
Did anyone see the 1987 soarer listed on prestiges website today? That would have been a nice run-around car.
I pointed it out to a workmate and he rang Geoff to buy it but it was already sold.
It was estimated to fetch over $11k landed but went for $19xxx.
i saw that...it looked like a weapon!!!
even for 19k, souded like a bargain (over 30 K in mods)
https://www.sau.com.au/forums/topic/35586-my-new-toy/page/2/#findComment-718824
i bought my r32 privately around late december/early jan and still havent received import approval. i hope yours is accepted fastret han mine was cause its really starting to piss me off
also that soarer is the biggest sleeper
ultimatepowder : i love that turbo warning picture. i found someone on another website with the same picture a while back and had to save it on my computer. i would love if someone made a sticker of that
https://www.sau.com.au/forums/topic/35586-my-new-toy/page/2/#findComment-718840
Don't forget Dluded you have to import according to month now
Unless you bought it before the cutoff date where they introduced that rule (Before September you wouldve had to have bought it) otherwise you'll have to wait till the month of manufacture. Maybe thats why they havnt approved it?
https://www.sau.com.au/forums/topic/35586-my-new-toy/page/2/#findComment-719457
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
