  • Replies 48
Anthony is easy as to deal with - bought a few things off him now and they've worked, been as described etc, so yeah. I'd buy off him again.
Cheers man!
hey anthony,
im located in sydney, and im looking for a sump and water pump.
if u have them in good condition how much would you want for them?
cheers,
hey anthony,
cheers,
bump
Are the front guard liners in good nick/undamaged? (bits that go in-front of the wheels, behind the inter-cooler area, and attach to the bar, not the upper bits inside the guard itself)
g'day mate... there are some rubber mounts that are used to attach the top of the radiator to the front reo bar. do you have them??
Hey,
I'm trying to chase down the blend door motor for the air-conditioning system. It is located on the left side of the driverside footwell. Little black box with a rod poking through to the passenger footwell.
I'm in Sydney, PM me if you like.
Cheers.
G'day mate. Woh I hope noone was hurt in the accident. Looks nasty. Sad to see.:(
Anyways... Do you have the standard boost solenoid? How much to send to Canberra 2911?
What wastegate actuator? Am after the R32 10psi. $$$?
Cheers. Rob.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
