Been a while since we've had one of these so thought I'd post it up.
Just wondering if anyone is interested in having a Dyno Day at ESP in May sometime? On one of the weekends. Currently it looks like ESP will be able to host one sometime that month.
https://www.sau.com.au/forums/topic/356076-eoi-dyno-day-at-esp-in-may/
  • Replies 59
Suspecting my car is going to be offroad at this time for at least a month.
If it's not a weekend when I'm on holidays, more than happy to help out though :)
Should see if we can get the Supra guys involved again. Was good last year.
If we were strapped for numbers I could chuck the S3 on but I wouldn't expect much from the stock engine :)
What date did you have in mind Chris?
And surely since it's not a driving event the Supras would come out of the woodwork? :nyaanyaa:
Confirmed date of 7th May
1: CeJay
2: Frink
3: MAG86
4:
5:
6:
7:
8:
9:
10:
11:
12:
13:
14:
15:
16:
I would want at least 15-16 people in on this, as people always drop out. Can have more of course. Price would be 50$ for members of SAU / Supra club 55$ for non members.
If I don't get enough numbers by April 7th or so, will cancel this, as I don't want to stuff ESP around.
I would be keen to throw the TX3 onto the rollers and see what sort of power output that she is making :D should suprise a few people i'd think
Can keep up with a 350z up to 160 kph so would be interesting to see what sort of power it is making at the front wheels when it is not hitting boost/fuel cut haha
Sounds like we may need to join on with another club to get the numbers.
It's been awhile since my car's been running full numbers, so I'll turn up.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
