Hi everyone,
I seems to be having a weird problem. Since last night the rear lights wont turn off, i checked if i forgot to just turn off the light switch but that was off. I had to take off the battery to turn the lights off. Dunno what the problem could be, never had it before. I did a search on here couldnt find any answers.
The car is a '96 r33 gtst
Thanks in advance
https://www.sau.com.au/forums/topic/356244-rear-lights-wont-turn-off/
This is for a Nissan Pathfinder/Terrano but it might be applicable to R33's (I am not going to contort myself to check on my car lol), but there are two plastic buttons or caps attached to the brake pedal metal arm or bracket next to the metal arm, I can't exactly remember. But sometimes those plastic buttons fall off or become worn out so you will have a constant brake light. Or it could be the brake light switch which is near where the plastic buttons are. Easy problem I think.
Yea, when i went to check down there i noticed that plastic button on the carpet which was broken, it should be an easy fix but i dont know where i'm gonna get one of those small buttons. pinch.gif Maybe the local nissan dealer could have those buttons for the pathfinder, gonna check that out.
Thanks for your reply
The plastic button itself is a clip, so you could use a metal machine screw with a similar sized dome head, circumference and height wise, washer and nut, combined to make a relatively indestructible replacement. Ah but then the plastic button lasted more than a decade so there is probably no point in it (but a good idea nonetheless).
Alright! I couldnt have think of a better way to solve this. I saw that there was another plastic button on the clutch peddle that didnt seem to be connected to any sensor, so i took that one off and put it on the brake peddle but that one lasted a day.
Thanks for the replies guys, really appreciate it.
  • 3 years later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
