I have some fairly serious overheating issues... its getting worse and worse. got a 52mm alloy rad, clutch fan, new water pump and thermostat and basically whats happening is after 1-2 laps it starts reaching 100.. takes a bit to cool down.. then if you get it back down to 90 and do another lap it shoots up to 110 and boils the coolant out... refuses to come back down even with a cool down lap and water squirters on. worst ive seen it was 120 degrees :(
any insight?
https://www.sau.com.au/forums/topic/356266-cooling-system-issues/
  • Replies 80
suggestions for better rad? im open to anything atm. it cant be higher then current r32 radiator due to the s14's lack of room.
as for blockage i doubt it.. cooling system is pretty new, only run coolant, rad is only 12 months old. but i spose anythings possible
Do you have the factory shroud on the radiator?
Thermostat might not be opening all the way (especially if it's some cheap trident one).
By clutch fan do you mean the factory viscous fan?
I would throw a new radiator cap at it, it's strange that coolant would boil at 110c which is why I suspect it.
We know water (ordinary tap water by itself) boils at 100c at atmospheric pressure, for every 0.1 bar of pressure the cooling system is under, the boiling point raises by approx 3 degrees C, 1.2 bar cap would be ~136c while a 0.8 bar cap would be ~124c. Coolant has a higher point than pure water and is dependent on the mix ratio, if coolant is indeed being boiled at 110c it would seem the current rad cap is holding little to no pressure.
almost makes me wonder if the cap area one the radiator is actually allowing a good seal or not.. it is a cheap shit radiator after all.
yeah it gets hot.. then pushes the water into the overflow and then boils. every time it does this the radiator level is lower and with air in it.. then it gets worse. kinda a chain reation.
I think a key question has been overlooked.
What kind of intercooler in on there?
90% of the time overheating issues are caused by cheap intercoolers that don't allow enough airflow into the radiator.
Not saying it is definetely the problem in this situation, but it is definetely something that should be asked.
How much higher is the engine than the rad? You could be trapping air if the motor is sitting to high relative the rad. If thats the case an air seperation tank will solve your problem.
nah defo not trapped air in there.. have bled it properly til no bubbles coming out the bleed screw.
nothings changed either,.. and the problem has got worse over last few events so something is up
+1 for the crossflow idea, think the desert coolers have triple pass , also about 700$ >_<
but i noticed with my 52mm the bulk of the water just flows through one side of the radiator, meaning the passenger side isnt really doing alot..Even if you rev the sucker (and i revved it to 6k) not alot pushes across because the tubes are so big they flow it all straight down..
Is it dual core?
Of course thats sitting still, bit hard to see what its doin on the move, but could still be an issue
I reckon having some kind of diffuser at the top inlet that even sent half the fluid to the other side of the radiator could be of some good
I drew a crappy pic of the top tank to give you an idea what i mean..
eDIT>.Yeah or dud cap...:laugh: mine came with 1.1 but think standard is 0.9
Problem is for a triple pass to work outlet needs to be on the opposite side, Im not sure how it would work with the inlet and outlet being on the same side :ermm:
unless you did it this way but its only double passpost-65674-0-80198400-1299383045_thumb.png
or possible quad...lol
Edit ..just realised you said triple core not triple pass..
I think you have other issues though if it is getting worse with each run
yeah i wonder the same thing, the triple pass that the alot of the v8 guys use, where the coolant is actually going down and then back up again surely would put strain on it, But alot of them are running big electric pumps, but still. They are advertised as having "little or no adverse flow restriction" although nothing is listed for anything other than old muscle cars .i think PWR or someone do them too.. Side to side wouldn't be too bad I dont think.. As the pump is now only pushing water through less cores at a time (although effectively twice as long ) there would be more pressure allowing it to actually flow faster..
Are the oil temps doing the same thing?
If not, then I would do as above and make the coolant double pass if you can. Hard if the tanks are top and bottom, easy if they are on the side (which on a skyline they almost always aren't)
You could also try a lower flowing water pump. Flowing too fast causes cavitation and, therefore, higher surface tension of the water. A lower flowing pump in a car that revs much higher constantly can often be the only thing required to get those temps back down.
Or you could try an electric one
i feel nismoid and elite mighta hit it on the head, its just flowing too much too quickly, have you got a smaller or standard radiator you could try even. If this is the problem it sucks cause i got the same radiator :( ,42mm might have been a better option, may just be a classic case of bigger isnt always better.
take the car to a garage, get the exhaust probe that normally goes in the tailpipe, but put it in the expansion tank for the radiator, dont let it touch the water ,,just let it sniff, any hydrocarbone reading will show hg failure.. easiest and cheapest way to check.when combustion pressure on a failed hg is the fault and pressure is getting in the water system then also cylinder fumes are in there too, the probe will pick these up..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
