Hey Jeff,
Ur a legend mate, I followed your instructions and got my unit to work momentarily. Here is what happened:
1. Measured the voltage, one of the 3 points measured 1.7 volts.
2. Adjusted it as high as possible to 2.2 volts
3. Turn the car on, 4wd and abs light remained on.
4. Turned the car off and adjusted my after market torque splitter higher (more front wheel bias setting). I'm guessing this increases the voltage too??
5. 4wd and abs light went off and all was working well.
The unfortunate thing is that it stopped working this morning :( any idea what I néed to replace on the board to get it to 2.5 volts and remain there??
Ps good on u for taking the time to trial build a new unit mate. I think there r a lot of ppl who desperately want to fix their gtrs. After all driving an expensive 1500kg gts-t is not much fun is it :P
Hi Jeff, good to hear that you are looking at new ideas, look forward to seeing how things progress. Would love to get my unit working again as the car has been in 2wd for a while now.
BTW mine too does not go above 1.6v, I think one of the voltage pots is buggered up.
Jeff,
i reckon if you build a working new unit, you could retire off it lol, theres that many GTRs limping in 2wd!
update on mine - works if I start the front of the car facing up the hill. haha, better than nothing i guess!
Did a tutorial on actually getting to the g-sensor the other day. Here's the link if anyone is interested..
http://www.skylinesaustralia.com/forums/topic/376142-r32-gt-r-lateral-g-sensor-check-and-more/
Without seeing whats on the other side of the PCB, the underneath pictured is very simple - three quad op-amp chips taking input from what I'm assuming are the G sensors on the other side of the board.
Surely someone has a crook one here in Melbourne that wants it fixed....
Hey Jeff,
Hey mate. Not sure why it would start then stop working unless the pot moved just a tiny bit and flipped the bias voltage low. Might have happened as you set it really close to max... So it would only take a tiny bump...
Awesome to have Bozz onboard. The accelerometer is actually a really cool old school design. Is uses a magnetic pendulum suspended in about 30000~40000 weight silicon lube (for dampening) and a hall effect sensor to measure its position. Not sure witch components drift over the years... I'm guessing the hall effects. But they are moulded into the housing. I think (if I remember correctly) they there were the only components on the back side of the PCB. But when I pull it out again. (Hopefully this weekend) ill check. I was more interested in going digital so I could fiddle with settings on the fly etc, I kinda didn't look into the root cause of why the sensors drift and die. Does anyone have a broken unit that maybe they could donate/lend to Bozz or myself?
If you need a better quality image Booz of the top drop me an pm with your email.... There were also some resistors on a little side PCB between the output of the top PCB and the header... Didn't look like it did much so I didn't take a pic. Originally the pic was just for myself so I knew what it looked like before I fiddled with components.
I think the op-amps have gone are EOL but there might be a drop in ??? (haven't looked...)
Awesome to have somebody else gett'n into this.
Just landed back in Adelaide yesterday.... so I should be able to take a look at stuff as needed...
Jeff
Sent from my HTC
I'm in two minds about a digital accelerometer - the R32 4WD system is well known to be shit on a track and all the aftermarket stuff does is feeds different signals into a slow and shitty controller to try make it less shit in some situations.
An awesome project would be to replace the 4WD control system (leave the factory ECU doing ABS) with a MEMS accelerometer such as the ADXL335 coupled to an Arduino Duemilanove. $40 gets you the new sensor, new controller running at 16MHz and you can make it do whatever you want, track, drift, playstation :)
But back on topic, it would be good to play with a broken sensor as it's unlikely all three axis are broken so I could spin it up and plot the force/voltage and pretty easily make a new unit with a MEMS accelerometer. After the design work, I reckon a replacement adjustable accelerometer could be manufactured for under $100.....
Sent from my laptop using Firefox
Yeah I totally get what you mean. I'd love to have the time to totally replace the controller with something better, but as i'm always so busy with work I don't want to start something I'll never get around to finishing. I agree, def would be the better choice... I'd love to have the source code of the current controller, just looking at the maths would be sweet. I think to start with i'm gonna stick with just a digital replacement for the G-sensor. But, if you wanna have a crack at replacing the controller I'd sure be interesting in lending a hand (if you want it).
My bro is also in Melbourne (sort of) and has a R32-GTR i'm sure avail for testing etc.
Just started the schematic etc for the digital G-sensor. I use the latest Altium Designer but can release it in whatever file type ppl want when it's done. (Maybe just the Gerbers so ppl can order the PCB's etc ??) The unit i'm building is a little overkill as I'm also going to use it for another project, but yeah I reckon around too that about $100 would be about right for a cut down unit just to replace the G-sensors.
Jeff
  • 5 weeks later...
Almost ready to send the PCB away... Just wondering does anybody have an R32 G-Sensor (a really good one) they I could borrow for some testing ? I think mine is ok, but i've done some tweaking so i'm a little unsure how "original" the outputs now are. I'll be at SAU Nationals (Just the Race Day - spectating) I can post it back after i'm finished with it... I don't plan on opening it up or anything so nothing *should* get damaged - I just want to monitor the output against my new replacement when it's up and running.
Cheers,
Jeff
My mate has a 32 with a cracked g sensor, its probably had a large shunt. Can this be repaired? Otherwise he will be interested in your board design if it works as planned.
If the G-Shock indicator has gone red then it's probably still fine (or might just need the bias voltages adjusted as per my pic at the start of this thread) If the whole unit has cracked and the silicon dampening fluid has leaked out of the hall effect / magnet pendulum cavity then it's prolly NFG. I'd take the top off and adjust the bias voltages first. If it's been hit the worst thing that can happen is that the magnets mounted on the small pendulum spring will be bent a little (ok) or bent a lot (nfg unit) inside it looks like this
Just pretend the magnet is a rock mounted on a piece of string. (Really it's a magnet moulded in a lead weight mounted on a spring all sitting in some thick fluid.)
"x"'s = Fluid
----------------------------------------------- (PCB)
xxxxxxxx|xxxxxxxx
xxxxxxxx|xxxxxxxx
xxxxxxxx|xxxxxxxx
xxxxxxxx|xxxxxxxx
xxxxxxxx|xxxxxxxx
xxx(Magnet)xxxx |Hall effect sensor|
As the car undergoes g-force the magnet moves closer or further away from the sensor.
After years of movement or an impact they look like this (Dramatised) (Edit - this should look bent to the right - added x's so the alignment works)
xxxxxxxx|xxxxxxxx
xxxxxxxxx|xxxxxxx
xxxxxxxxxx|xxxxxx
xxxxxxxxxxx|xxxxx
xxxxxxxxxxxx|xxxx
xxxxxxxx(Magnet) |Hall effect sensor|
And therefore the output of the op-amps feed from the sensor needs to be re-calibrated, the bend in the spring taken out, or the unit replaced.
Hope this helps a bit and that the text pics look ok
Jeff
Edited by datsun_1600
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
