I know this was discussed in the Wasteland for a bit, but deserves its own thread to mange who's going meet ups ect
I will be there with the Vodka O team in the Australian GT Series all 4 days, (so make sure you support our Lambo and Porsche out on track!
we have 25 confirmed entries (no pink GTR this year), and an Hour Twilight race on the Friday which means glowing brakes and exhaust flames
Guess some other will be there to watch the taxi's trundle around the track a bit.
A popular time for SAU meet ups has always been at the "fashion" shows running saturday and sunday behind the grand stand
https://www.sau.com.au/forums/topic/356869-2011-clipsal-500/
checked the long range weather forecast......not lookin good
warm but rain every day
Frid = 35 Rain
Sat = 28 Rain
Sun = 27 Showers clearing
Aside from the sucky humidity, the rain should make for a more interesting race, no? :)
-D
That weather forecast is bloody PERFECT Sled .... nice and warm (but not inanely hot like many years), and a bit of moisture makes for VERY interesting races and some awesome stacks!
I'll be there working hard on the Saturday and Sunday
apparently some clown will be dressing up in uniform and trying to sell the Army Reserves to people
:rofl:
easy money, and can wander around during the day too :D
I like my weekend's to include some moisture :nyaanyaa:
Will be in Rundle Mall with the GT cars from 9.30 Wednesday
Hi Guys,
I will be coming over thursday morning for the weekend.
I work with globecam/V8 SC TV doing the incar cameras for all the classes.
It looks like its going to be a busy weekend with about 20 cars to rig plus the V8's.
Hopefully the weather plays nice too.
Cheers
Luke
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
