Sweet, driving there in the 34?
Yes Mike,
Getting Nismo skirts and pods fitted; and even front splitter painted all to Bayside Blue body colour > picking it up on April 30.
I have the option of putting Titanium RE30s on it or keep the Gold/blue ADVAN RGs on.
Lovely Pearl Black R34 GT-R will be making its appearance too.
This time with Bronze LMGT4s.
May 1st forecast has changed from cloudy to possible showers atm.
Happy B'day Kristian. Pity we can't see the N1!
Awesome
I'll be sure to look out for ya,
Damn I just realized I maynot have my car as it's getting the front bar resprayed cause some old bitch scraped or trying to park her car, I'm going to try and postpone it till next week
Hi guys,
We got a call this morning from Auburn City Council advising us that due to the recent heavy rains, Silverwater Park was closed to all sport activities this week, and wouldn't be suitable for cars to drive on this Sunday. They don't want their grounds getting wrecked so we have to accept their assessment of the situation. (We don't want cars getting bogged on there either, especially if it meant we had to pay for repairs to the reserve).
The plan at this stage is postpone the event - we're looking at either holding off till spring, or doing it in a few weeks' time (which will put us fairly close to winter). Like you guys, this has caused enormous inconvenience (and cost!) for us, so please be patient with us while we sort out a new date.
We'll let you know as soon as we have more information.
Cheers
The AJD crew
Hi guys,
Cheers
The AJD crew
So this means Kristian will be coming up after all (with his N1), unless he has another birthday this year! :P
Damn there goes my Sunday
Same.
But if it's held in Spring it'll hopefully be a bit warmer; the weather will probably be just as unpredictable in Spring, but we should be heading for a drier summer next year as opposed to the tropical one we had this year.
Yeah other plus points will be Kristian's N1 and even more time for people to join up. How can there be more quality JDM cars in Adelaide than Sydney?? :)
  • 1 month later...
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
