Hi just about to start building my engine, one of the stock pistons gave away because of some overboosting problems with the stock twins. Bought some GT2871R(GT2860-10) Turbos and just ordered some stuff to build the engine.
here is what i ordered, will add engine build pics once everything arrives.
CP Piston Set with Rings // 86.5mm(0.02")
Eagle H-Beam Connecting // ARP custom age 625 series bolts
Nissan N1 Oil Pump
Tomei Combination Kit (1.2mm Thick, 87mm Bore)
・Metal Head gasket
・Metal Throttle Gasket
・Metal Intake Manifold Gasket
・Metal exhaust Manifold Gasket
・Oil gallery orifice
ACL Race Series Con Rod Bearings
ACL Race Series Main Bearings // Standard Oil clearence
ARP Head Stud Kit
ACL Race Series Camshaft/Thrust Bearings & Small End Bushes
Nitto Oil Pump collar
Mods
. Twin GT2871R // ported stock manifolds and ported exhaust housing to match
. Kakimoto 3.5" full exhaust system
. Exedy Twin plate clutch
. Greddy FMIC and pipes
. VEMS Standalone - not installed yet
. Deatschwerks 870cc Injectors - not installed
. HKS EVC 5 Boost controller
. Zeitronix Wideband + EGT
. 2x Blitz bov´s
. N1 Waterpump
. HKS Kevlar Cambelt
. Nismo Oil cap
. Nismo Radiator cap 1,3 Bar
. Nismo engine and transmission mounts
. NGK iridium sparkplugs
. Nismo transmission mount
. Driftworks upper links
. Defi Watertemp gauge
. Full Roll cage
. Apexi coil-overs
. TBO Bodykit
. Abbey Motorsports valve covers
. Volk racing 17x9" wheels
. Xenon Headlights 8500L diamond white
Pics of the car
skyline853-1.jpg?t=1288148474
The turbos and ported manifolds
GarrettGT2871R.jpg?1286908043
and the piston that got wrecked
https://www.sau.com.au/forums/topic/357143-tbo-r32-gt-r-iceland/
-10 turbos on stock capacity or u going bigger?
keeping it 2.6 ltr, not to concerned with lag since at first i planned on using a GT4202, 74mm Turbo with a T6 1.15 A/R. Also had a Supra with a precision billet 42-71mm turbo so im used to a bit of lag
The hotside was bit too big and i decided to go with the GT2871R turbos instead, but here are pics of the GT4202 // just put it up there to see what kind of space i was working with lol
harfeni140-1.jpg?t=1300391373
harfeni138-1.jpg?t=1300391377
harfeni137-1.jpg?t=1300391375
and here is the Supra
MySupraEnginebay2-1.jpg?t=1300391752
Edited by R32GTR/Iceland
  • 4 weeks later...
a little update , the stuff that i ordered is finally here. Just have to wait for the block to be bored and then i can start assembling everything :)
here is what came in the package
Eagle H-Beam Connecting rods // ARP 2000 fasteners
Nissan N1 Oil Pump
Tomei Combination Kit comes with
*Metal Head gasket(1.2mm Thick, 87mm Bore)
*Metal Throttle Gasket
*Metal Intake Manifold Gasket
*Metal exhaust Manifold Gasket
*Oil gallery orifice
ARP Head Stud Kit
2x- Nissan OEM Cam Seal for RB26DETT
Nissan Rear Main Seal for RB26DETT
shitty phone pics hehe but always fun to open these kind of packages
skyline639871234_6887645_3246471_n.jpg?t=1302730101
skyline639871234_6887622_7881410_n.jpg?t=1302730099
skyline_639871234_6887608_6478537_n.jpg?t=1302730102
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
