Thats right. Any ideas? It appears to be coming down the engine loom. Car is an R33 gts25t 4 door 1997. Tuner has only come across a few cars that have done it and he is baffled.
Any oil leaks in the engine bay? As it could be leaking onto the loom and working it's way through?
Not that I can see, someone just pm'ed me and suggested it could be the air-con overflowing and it can have a yellowish tinge to it. There are also drips on the front of the left hand passenger's mat toward the firewall under a fan.
Air con overflowing? This does not happen. Lower high pressure sure but not overflowing
Possibly meant the evaporator is blocked and icing up or the drain is blocked. Both could cause water leakage into passenger foot well
But if your sure it's oil the best thing to do would be to look in your engine bay for major leaks. As the ecu is on the passenger side, the only oil near there really is from your turbo lines and rocker cover, but these are a fair way from the main loom to the ecu. Check around power steering area. Put up a photo of the ecu and surrounding area if possible
As above send pics through.
Have had cases of Coolant Temp Senders leaking and then the coolant getting onto plug and making its way UP the wiring to the ECU and corroding that pin and several around it.
Couldn't believe it first time I saw it but seen it a few times now (damn Audi's).
So check for leaks and post pics of ecu if you can.
If oil is on particular pin in ECU check what that pin is for.
But shouldn't be too hard to diagnose. It is only an oil leak at the end of the day
I'll have a look in the foot well and see if I can take some photos. Tuner told me it was engine oil... unless he was mistaken. I just don't see how it could be.
How's your aircon? Aircon lines have a lubricating oil in them for the pump. Could it be that?
If it's coming down the loom, just trace the loom back. Could it be (dirty) powersteering fluid? Unwrap the loom and find where the oil comes from that way. just rewrap it with the spiral shit and duct tape.
Just opened the kick board to see where this sludge is coming from. It is rather sticky and brown where it has been sitting for a while.
This is where something has been dripping onto the mat (I am assuming). Patch is at the front left hand side of the mat under the dash and a little on the edge where the computer is.
Oil on the ecu plug (Some might be form the tuner smearing around).
Thing above the drips on the mat.
Highest point I can find the brown liquid on the fire wall (see the brown patch) left of the wires. It is not far above the ecu but on the back wall.
You can see it running down and puddling on the floor near where the ecu sits.
A/C Compressor is located at the front of the engine below the power steering pump from memory.... If it was from that it would have a definate fluro green tinge to it.
It must be traceable, Just try your best to look along the main harness. If you cant see it on the engine bay side then something may be leaking down the firewall?
Does your car noticably lose oil when you go to service it (Does the oil on the dipstick go down between services)?
Goes through no oil at all. I can't see any leak on the engine bay side. It is only part way up the firewall and then stops. I felt the outside of the loom up higher but it wasn't wet from what I could tell. What is the fan above the mat? It could be from that and could make sense.
If I unplug my tuned ecu will it reset it and loose the tune? I am quite keen to open it up and clean it out a bit. I don't mind a little leak if its not important, but I want to stop it getting into the ecu.
Edited by senilykSkylines
fan above that mat is your A/C fan that blows the air through the vents in the car... The evaporator is in front of that and your R134a A/C refrigerant as atmoised liquid to cool your air down (so there is A/C refrigerant around this area, but as I said it should be a fluro green colour, Does your air con work in your car? Because a leak like that from the air con would make your air con stop feeling cool by now for sure)
Depends on the ECU
I can only confirm that a Power FC will not lose its tune if unplugged
Depends on the ECU
Air con is cold but not as cold as my bosses' 96 stagea so I am assuming it is getting a little old.
  • 3 weeks later...
Mechanic told me today it is the VVT solenoid leaking oil down the engine loom. I will need to get it replaced. Is this a job that I can do myself? Where is it on the engine?
He reconed he had never seen it on a Nissan before and he thought it was mainly a Subaru problem.
Dan
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
