Thats right. Any ideas? It appears to be coming down the engine loom. Car is an R33 gts25t 4 door 1997. Tuner has only come across a few cars that have done it and he is baffled.
Any oil leaks in the engine bay? As it could be leaking onto the loom and working it's way through?
Not that I can see, someone just pm'ed me and suggested it could be the air-con overflowing and it can have a yellowish tinge to it. There are also drips on the front of the left hand passenger's mat toward the firewall under a fan.
Air con overflowing? This does not happen. Lower high pressure sure but not overflowing
Possibly meant the evaporator is blocked and icing up or the drain is blocked. Both could cause water leakage into passenger foot well
But if your sure it's oil the best thing to do would be to look in your engine bay for major leaks. As the ecu is on the passenger side, the only oil near there really is from your turbo lines and rocker cover, but these are a fair way from the main loom to the ecu. Check around power steering area. Put up a photo of the ecu and surrounding area if possible
As above send pics through.
Have had cases of Coolant Temp Senders leaking and then the coolant getting onto plug and making its way UP the wiring to the ECU and corroding that pin and several around it.
Couldn't believe it first time I saw it but seen it a few times now (damn Audi's).
So check for leaks and post pics of ecu if you can.
If oil is on particular pin in ECU check what that pin is for.
But shouldn't be too hard to diagnose. It is only an oil leak at the end of the day
I'll have a look in the foot well and see if I can take some photos. Tuner told me it was engine oil... unless he was mistaken. I just don't see how it could be.
How's your aircon? Aircon lines have a lubricating oil in them for the pump. Could it be that?
If it's coming down the loom, just trace the loom back. Could it be (dirty) powersteering fluid? Unwrap the loom and find where the oil comes from that way. just rewrap it with the spiral shit and duct tape.
Just opened the kick board to see where this sludge is coming from. It is rather sticky and brown where it has been sitting for a while.
This is where something has been dripping onto the mat (I am assuming). Patch is at the front left hand side of the mat under the dash and a little on the edge where the computer is.
Oil on the ecu plug (Some might be form the tuner smearing around).
Thing above the drips on the mat.
Highest point I can find the brown liquid on the fire wall (see the brown patch) left of the wires. It is not far above the ecu but on the back wall.
You can see it running down and puddling on the floor near where the ecu sits.
A/C Compressor is located at the front of the engine below the power steering pump from memory.... If it was from that it would have a definate fluro green tinge to it.
It must be traceable, Just try your best to look along the main harness. If you cant see it on the engine bay side then something may be leaking down the firewall?
Does your car noticably lose oil when you go to service it (Does the oil on the dipstick go down between services)?
Goes through no oil at all. I can't see any leak on the engine bay side. It is only part way up the firewall and then stops. I felt the outside of the loom up higher but it wasn't wet from what I could tell. What is the fan above the mat? It could be from that and could make sense.
If I unplug my tuned ecu will it reset it and loose the tune? I am quite keen to open it up and clean it out a bit. I don't mind a little leak if its not important, but I want to stop it getting into the ecu.
Edited by senilykSkylines
fan above that mat is your A/C fan that blows the air through the vents in the car... The evaporator is in front of that and your R134a A/C refrigerant as atmoised liquid to cool your air down (so there is A/C refrigerant around this area, but as I said it should be a fluro green colour, Does your air con work in your car? Because a leak like that from the air con would make your air con stop feeling cool by now for sure)
Depends on the ECU
I can only confirm that a Power FC will not lose its tune if unplugged
Depends on the ECU
Air con is cold but not as cold as my bosses' 96 stagea so I am assuming it is getting a little old.
  • 3 weeks later...
Mechanic told me today it is the VVT solenoid leaking oil down the engine loom. I will need to get it replaced. Is this a job that I can do myself? Where is it on the engine?
He reconed he had never seen it on a Nissan before and he thought it was mainly a Subaru problem.
Dan
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
