I am organising another group buy for NM 35 Stagea Sway Bars. We require a MINIMUM of 5 orders to go ahead.
Whiteline; http://www.whiteline.com.au/index.php have just added these exciting new products to their lineup! These bars are so new they do not even appear on Whiteline's own website yet!
Whiteline have used their years of experience and on car G-meter testing to ensure these bars are a prefect match for the Stagea
PLEASE CHECK THE REVIEWED PRICING:
Front 32mm Blade adjustable; RRP; $320. Group Buy price; $235
Rear 20mm Blade adjustable; RRP $285. Group Buy price; $210
So the front bar has to go from $210 to $235, and the rear bar has to go to $210.
Rear Heavy Duty Ball Link Adjustable; RRP $175. Group Buy price; $115
Heavy duty Stainless Upper Link Mounts; $60
You can order any item individually, or all of the above to make your Stagea a corner devouring beast!
Delivery is not included in this price, and rather than quote a "one size fits all" cost, contact me with your postcode for an accurate shipping cost.
As I live in Faulconbridge (Blue Mountains), all those wishing to come to me are welcome; otherwise I am happy to travel a reasonable distance in the Sydney area to deliver at no cost!
This is a massive saving over retail, and an excellent chance to get hold of fantastic quality components that will really improve the handling of your wagon!
Due to the one off nature of this product, I will requre FULL payment by 15th April 2011, and delivery is set to be around 2 weeks later; 29th April onwards(actual delivery date may be a little earlier or a little later) depending on manufacturing lead time.
Please PM me for a shipping quote BEFORE depositing any funds.
Rest assured, I will be keeping in touch through the process, and in contact with all purchasers once they're ready!
Banking Details;
Dale Laughton
ANZ Bank
BSB; 012-836
ACC; 5333-44981
When making a payment, please use your forum user name as a reference, so I can confirm payments.
So let's get cracking!
Cheers, Dale
Remember, the more people we get on board; the better chance we have of Whiteline making more products for the NM35!
Follow the link to the group buy section. http://www.skylinesa...-bar-group-buy/
Edited by GoldZilla
  • Like 1
keen as hey man can i see if there is interets on the NZ skyline website see if you can get more numbers ?
Absolutely Dust, sorry I haven't replied to your PM mate. Go ahead, I'll be in touch with more detail for you today.
+1 on full package
Dale, I'm really impressed with your negotiation skills, hope no knee capping was involved... :)
Cheers for the huge effort... Well done!!! PM sent.
Thanks, didn't need to break out the knee pads either...:whistling:
+1 on full package
even if those knees were caped we still get the deal
+1 whole package just need to sus postage with you dalea we can sort that out closer to the day
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
