Hi,I've a 1998 Nissan Skyline R34 GT-T with an automatic transmission.I'm looking to modify it,I've been doing alot of research and spoke to a couple Japanese Imports Specialist like C-Red and Imports 101 here in Perth.They told me because my car is an automatic,the stock ECU is a little more restrictive compared to the manual one.Recently,I've been looking at Nistune.C-Red told me that they wouldn't recommend it for an R34,and likely to have problems with tuning in the long run,it's better to go for a piggyback ECU like Haltech or something which would cost around $2,000 to $3,000 mark.On the other hand,Imports 101 told me that the Nistune is quite reliable and alot cheaper compared to the piggyback (only around $1,200 fitted and tuned).It's true that you could have problems with it in the long run but very rare or unlikely.At the moment
I have podfilter,catback exhaust and a front mount intercooler and I'm running 11PSI boost,they told me if I want to stick with the stock turbo,you could be looking at around 200kWs at the wheels.
What do you guys suggest ? Should I look for brands like Motec,Apex'i or something ? Thanks
Edited by Jeremy1607
https://www.sau.com.au/forums/topic/357580-aftermarket-ecu-for-r34-gt-t/
  • Replies 63
This Tuner sounds a bit dodgy at best...
A haltec is NOT a piggy back ECU, it's a complete ECU, and from what I've read won't work so well with the automatic.
I'm fairly sure that NIStune is the only ECU that will handle the auto.
nistune is NOT unreliable, NOT hard to tune and the cheapest and best option.
I've got it in my GTT running dual maps PULP98 and E85 making 290rwkw .
the 200rwkw mark is correct for the stock turbo.
Pretty sure there is another thread exactly the same from you. We answered in there.
Its garbage, stock ECU is the best for an automatic. You can modify all the factory automatic settings. Nistune is an excellent solution and great value. I am running it with no issues and 280rwkw. There are guys with 400rwkw+ running it.
NIStune all the way, stay away from CRed, so not happy with their Haltech install on my wagon and the butchering of my loom they did.
Removing it in favour of NIStune (had a hiccup with a spare ECU that didn't work :( ) soon.
Send me a PM, I can get NIStune boards and I have a mate that fits them for me and will probably work for alcohol :)
Further to things said above, Haltech is not a piggyback BUT when fitting them to our auto cars (my engine/transmission setup is pretty much the same as yours but 4WD) they have to be wired in as a piggyback. The TCM isn't a seperate unit like the older autos, it is part of the ECU which means the stock ECU has to remain to control the gearbox. This is how mine was done and they did some other dodgy stuff like changed the water temp sensor to suit the Haltech which screwed up things controlled by the stock ECU that need certain temperatures to operate (VCT for example, would never engage because the stock ECU was seeing the water temp as 65deg instead of 85deg).
Also, my NIStune tuners of choice in WA would be Hyperdrive and AllStar Garage.
Edited by bubba
Okay,thanks.I will look around again and find out more information.
Do any of you know what's the maximum power you could get from the stock turbo ?
I want it to be as powerful as possible but at the same time I want to keep it safe for the engine (like if you run 16-18PSI on the stock turbo,the engine block can't handle it and it could blow up) and good fuel efficiency.
Dangerous territory bloke, this is probably the most common question asked on this forum. Do a search or look through the rb25 dyno results thread.
Max power on standard turbo is roughly 200rwkw, max safe boost is between 10-12psi.
Haha yeah I know,that means if I want anything more powerful than 200kWs.I need to go for a bigger turbo ? I'm running 11PSI at the moment.
Are there any other ways to make more power with the stock turbo or 200kWs and that's it ?
if you want more power than 200kw you will need a bigger turbo. that's the basic answer. and as far as fuel economy and reliability it's impossible to have them both with more power. as you make more power you WILL use more fuel. it's simple. to get more power your car must consume more air and more fuel to make it. and of course more power puts more stress on your engine so yes reliability will be reduced the more power you make. look at something like a GTRS bolt on kit. that will give you an easy 250kw. and yes the nistune is the best option for an auto R34.
Yeah,I understand.What's a GTRS bolt on kit and where can I find more information about it ?
And is nitrous oxide even legal to use on a car ?
Maybe I should for the Nistune first then (to make around 200kWs) ?
the turbo is made by HKS and it's called a GT-RS
if you google for GTRS youll find tons of pages of random crap
if you browse in the turbo upgrade section you should plenty of RB25s with GT-RS fitted
but its not a cheap upgrade
you need to upgrade
fuel pump
injectors
airflow meter
nistune
tune of nistune (or whatever option)
turbo kit itself
tyres
intercooler
so whilist the turbo kit may only be 2.5k the other stuff really adds up
Haha you mean,I should do research on my own regarding the GTRS bolton kit ? Okay,will do.
Just type in GTRS into the search field in the Forced Induction section and you will get heaps of info. Way more than a few people replying to your post here.
To be honest I dont recommend the GTRS kit, quite expensive and looses the factory appearance so cops can get you in trouble.
Get a hiflow turbo, GCG or Hypergear etc. Not to mention these will just bolt straight back on plus the fact they have factory appearance and about half the price of a HKS kit. Just saying this has all been discussed over and over before. So much info on here.
Okay,cool.Are there any other cheaper options that I can look at then ?
I mean $7,000 just to get 250kWs isn't worth it.If it cost $7,000 just to make 250kWs,how much would it cost to make around 300-500kWs ?
Hahaha
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
