  • Replies 43
Galois she is a :worship: 25GT with a RB25DE not the best of the best i know but you can realy feel its connection to its higher end relations. i do plan to paint it at the end of this year or middle of next but idk if i want a black or a dark green
Just had a thought...if Neo was colour blind...and nothing ever actually happened because of Morpheus' stupid pill test...
WOAH
But Neo would know regardless of colour because he is the matrix.
BOOM!
Lol whoa wot a trip out, no1 has asked about the skyline more your life story hahaha
Only on a friday ay...
http://www.youtube.com/watch?v=CD2LRROpph0
BOOM!
But what if the matrix got it wrong? What if green was really blue?
How would the matrix know what green really looked like?
So technically, they've never seen green. Or blue.
Starting to? You're a little late Pal :)
To be honest, it never really had a topic to begin with...if you can find a narrative I'll stick to it LOL.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
