Does anyone know if the translated manual has details like all the wiring diagrams, wire colours, plugs etc? Thinking of having a play with the stereo side of things in my car....
http://m35stagea.info/forum/viewtopic.php?f=2&t=43
What do you want to do? Just talk to Commsman or Ducati02?
Ryan, I'm flattered you thought I could help ;) . I've been chatting with Andy about speed signals and stereo problems recently.
I think it is the latter that he was hoping he could get more info about by finding the right manual.
I'm pretty sure he's looked at the Japanese and Infinity manuals & still has some questions, but that was where I would have sent him anyway.
Edited by Commsman
Yes I have the japanese manual for the m35 and the english manuals for the g35... but wiring colours and plugs are different between the two. I've been chasing the speed sensor wire for a while and in the G35 it's white with a green tracer at certain points- for example at pin 17 in the top dash display unit. We don't have a wire going to pin 17 on our cars....
The only way to go is an english conversion of the m35 manuals, but I don't really want to fork out the money if it's not detailed- the AV section alone of the jap manual is large with all the diagnostics, which would be handy.
Hi Andy, you may just have mistyped the pin number above, but in the DI (Driver Information System) manual for the G35 on page DI-14, it says at the back of the combination meter (dash) the terminal number 19 is the "Vehicle speed signal (2-pulse)". Is there a wire at that terminal?
I was looking at this last night, but thought there had to be a better place to pick it up from. What happen to the brown connector? No luck there?
Edited by Commsman
Sorry, should have clarified more. The speed signal goes to many places in the g35, one of which is the top a/c display in the middle of the dash. This is the easiest place to get at it if it doesn't appear to be working at the brown plug under the steering wheel (like mine). I really need to chuck a scope on the thing to see if the signal is there or not but am scope-less at the moment. The g35 manual describes a white/green wire at the a/c display and on our cars it's not at that pin. There is a white/green wire there but I'm not willing to take the risk until I've checked it properly.
Going back to the original question of the post- has the m35 manual actually been translated by jpnz? I'm sure I saw it for sale somewhere but on the jpnz site it isn't.
Edit: Found it m35 manual
Edited by andynogo
wow awsome has any one actually seen this??? is it good???
ive been going threw the jap manual in pdf format copying the text pasting it on a web site that converts it, it works but is just a pain in the ass,
I should have known you'd be all over this. I didn't see that it also appeared above the AC. That's an easier place to find it than behind actual dash display. I've got a speedo correction device I've been meaning to fit. I'll see if I can find a wire that works & let you know.
I wonder if you get the full manuals translated for your ~$140 (there's an awful lot of them for the M35) or a cut down version?
Shaun, I too had started doing this & I agree, what a pain. It's better than nothing I guess but I think I'd rather buy the manual, if it's any good.
Edited by Commsman
I think I might get one ,
Considering want to add speed correct , get the cruise control working
And put in a 2 way alarm with remote start and window up
Plus would be good for future incase mechanical issues ,or such things,
Can I ask what device u got , as will be looking for one soon ,
Yeah, I bought a heap of their kits a while back as I think they're (mostly) great value & I love DIY :)
I'll let you know how it goes if I can get time to put it in.
Nice
Yes I've had a few off there kits, had the electronic boost controller , air fuel controller and the hand controller in my old car didn't get it working but I just gave up to quick , now I got a lil more knowledge I think it would be easier ,
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
