ok, well aware this gets asked alot but there is to many variables. looking at either turbo in .82 IW patterm. im after 250-270ish with obvoiusly the most response possible, without having to cram boost in to make power. .Car has standard cams and will do so for a while.
1. assuming all variables are the same. what would be the spool difference between the two turbos at 1 Bar. (my reading is leading me towards 3071 is 3500ish, 3076 is 4000ish...correct?)
2. which one did you choose and are you happy with it?
these turbos seem to be the main two that pop up in discussion, but most are .63 ex gate. have spoken to garret, MTQ and the person tuning my car and have all confused me even more.
any help is appreciated, as i cant make up my mind
https://www.sau.com.au/forums/topic/358077-gt3071r-v-gt3076r/
  • Replies 119
Posted Images
lol, thanks simon. i thought i might get some non biased opinion here rather than the 3076 bashing from andrew and luke.
well you've had the 2 turbos, admittedly with different rear housings. what would you go for?
also when i popped down to MTQ, the 3071 now comes with the anti surge front cover :worship:
Both .63 rear though. And I dong want to run IW with the .63 due to the bOost issues. Also simon, could the response differences have something to do with e85?
If the lag is only a few hundred rpm. Then I'd just go the 76 for the head room. But getting up around 300rwkw is getting to be pretty useless for a daily/ curcuit car
:ermm: I dunno what threads you've been reading here but almost all the results here are ALL .82 and -IW
3071 is the turbo you want for 270rwkw. The 3076 is 280-300rwkw on PULP, 330rwkw on E85
Get the .82, be happy.
It's been discussed 100's of times here now and i really cbf'd typing much more about it. Go search if you want to see all the threads.
thanks. but from my reading and lengthy discussions with garret and their distributors, they cant offer an answer either other than go with the .82.
have you had experience with either turbo or just been reading on here?
that seems to be the way im looking at it. but then threads like this
http://www.skylinesa...ge__hl__3071+82
make the 71 seem the go.
thats my old car :)
go the 71 if yr goal is 270kw, its an awesome turbo
no point in having extra lag if the 71 will comfortably make that power
but be beware, you will want more power! they always do
I've had a 3040 in the past.
And as i said, there is that much info in the pages here, i cannot see why you'd even need to ask Garrett.
I don't think there is as much info as you think regarding the .82 IW. Have only found a few of each. thanks for the helpful post usmair, that's the experience I'm looking for.
I rang garrett for an opinion. Seems quite logical to me. 3040 isn't really relevant here. But thanks. I've also received info on 3082, also not really what I'm looking at
Thanks
If you don't want to cram boost into it then surely the 0.82 housing is the go. To make an each bet, order the 52 trim comp GT3076. GCG have them.
(edit: Ash's comparison to a GT3040 is valid as we are talking the same turbine and housing with a bigger compressor so anything smaller like a 71mm or 76mm comp will be even better)
Yeah .82 is a definate. Mostly due to not wanting to cram boost and the IW not liking the .63. My main question is how much earlier the 71 will come on than the 76. I've even read here that the 76 may come on earlier
Confusing stuff when your actually Trying to buy a product. And fwiw the price difference between 71 and 76 was $20 through mtq. I lold.
Well a lot of people used to think that the conventional , ie pre GTX , GT3071R was not really an ideal match of compressor to turbine as in getting the GT30 turbine to spin the 71mm compressor fast enough .
I've alwasys thought that the GT30 turbines trim size is a little big in this instance and its not someting you can get around by changing the turbine housing from say 0.82 to 0.63 A/R .
Also from what I've seen Garrett didn't seem to want to fit the port shrouded version of the T04E compressor housing on the GT3071R until the GTX version became available .
There are a couple of choices you have and one is the GTX3071R and the other the mid compressor trim version of the GT3076R ie 52 rather than the more usual 56 trim size .
I'd do some searching on what results people are getting from the GTX3071R .
A .
Thanks. I did look into the gtx3071. However mtq in sa said they have only sold a couple and haven't heard back from people. Even in the US it doesn't seem people ate spending the money on the gtx. At the end up the day I can't imagine power near 300rwkwwould be easy to put down in a street car
Joeyjoejoeshabadoo (sp) seems to be the ideal Case for 3071 (admitantly 2835 .67 or something). Making 260ish at 1 bar. Full boost about 3300. Sounds perect in theory
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
