I've had it for a little over four.
I don't see it going anywhere, anytime soon though.
Your phone on the first pic says 5 march 2011 and that was before you picked her up right?
Glad to hear you keeping her either way
Bringing it together
I like my cars as solid as possible. I had almost every brace known to man on the MX-5 and it made a huge difference. Being a convertible, it did have a lot of chassis flex in standard form. On the other hand, the Stagea is almost as solid as a concrete block, but there is always room for imporvement right?
There is a downfall though. Finding braces to improve it are hard to come by. So when this discontinued Cusco rear strut brace popped up on Up garage, I knew what I had to do.
Here’s hoping I can find a few more braces to whack onto the Stagea over time.
So I've been doing some light reading this morning, and I've noticed that people have said taht a S14 turbo rear subframe will fit the Stagea?
Just the subframe? no need to change shocks, or arms etc?
Also, another thing that has been bugging me (can't find much info on) are the diff's, is there a diff centre that we can drop into the Stageas housing? I guess it's either that, or getting my diff shimmed.
yeah he did, I'm curious if the RWD and AWD stagea subframes are the same though?
But Grant (Yokotas13) did say it bolted straight up, many moons ago. He isn't very eloborate though (never has been).
should be, only the manual and auto are different. might have issues with diff ratios tho, gotta find out what the front diff is so you can match it up,
you'd probably need shorter/manual half shafts too. rear arms are the same, sway bar is the same.
might be easier to get the rear end out of 33 gtst??
And your coilovers propably won't fit, being auto, you'd have eye type, you'd need to get some fork type ones if you change the entire rear end.
Well to my understanding, the Cradle itself is a direct fit, without changing anything else (i.e remaining Stagea parts will bolt up). If that's the case, I'll be more than happy to do it and get some wider wheels on in the future.
If not, meh.
sent a PM to Mike earlier today, keen to hear what he has to say.
Darrinspencer has done one from memory.
he did 260rs cradle.
i did s14, everything lines up, i used the same diff i was running but obviously needed to use the shorter half shafts. lower control, camber, toe and traction arms are all the same and interchangeable.
while the cradle is out, replace the subframe bushes with whiteline units or equivalent
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
